how do i test the my plug wires #934552
02/21/11 10:25 PM
02/21/11 10:25 PM
United states wisconsin
bigblockbryan Offline OP
how do i test my plug wires to see if there good if there not im gonna buy some fire cores i have acells
Re: how do i test the my plug wires [Re: bigblockbryan] #934553
02/21/11 10:28 PM
02/21/11 10:28 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
OHM meter
Re: how do i test the my plug wires [Re: Bill MeLater] #934554
02/21/11 10:31 PM
02/21/11 10:31 PM
Kirkland, Washington
Pacnorthcuda Offline
OHM meter
Run your hands all along the wires while the engine is running and report back any findings.
Re: how do i test the my plug wires [Re: Pacnorthcuda] #934555
02/21/11 10:33 PM
02/21/11 10:33 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
OHM meter
wet your hands first for better test results!
Re: how do i test the my plug wires [Re: mikemee1331] #934556
02/21/11 10:43 PM
02/21/11 10:43 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
OHM meter
You failed to mention that in your coil test procedure!!
Re: how do i test the my plug wires [Re: Dcuda69] #934557
02/21/11 10:49 PM
02/21/11 10:49 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i nearly fell out of my chair laughing when i read 'Pacnorthcuda' reply! i sincerely hope no one takes these responses seriously.
Re: how do i test the my plug wires [Re: mikemee1331] #934558
02/21/11 11:27 PM
02/21/11 11:27 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
if in doubt...change them out....
Re: how do i test the my plug wires [Re: bigblockbryan] #934559
02/21/11 11:37 PM
02/21/11 11:37 PM
Mike is the man . Ohm them then have a helper wiggle the ends while you are manning the meter & see if the reading jumps. Bryan what symptoms are you having? EDIT open the hood at night & let it idle & see if you see any arcing & have a helper power brake it to up the load
Re: how do i test the my plug wires [Re: bigblockbryan] #934560
02/22/11 09:47 AM
02/22/11 09:47 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
About the only practical test that an owner can do with common equipment
is to first Ohm test the center conductor,
then re-install the ignition wires,
move the vehicle to the darkest spot you have available,
then (keeping hands safely in clear)
watch the running engine in the dark
for the distinct blue-green color
of 'Corona Discharge'
If there is an electric motor repair shop nearby,
most good shops will have a
'Hi-Pot Tester'
capable of going to at least 4000 volts.
With a Hi-Pot tester
you would connect to the center conductor of the ignition wire,
then dip the middle section of the insulated wire into salt water,
with the ground of the Hi-Pot tester also in the salt water.
Don't submerge either end of the ignition wire where the plugs and exposed metal is.
Good wires will show at least one MegaOhm of insulation integrity.
If you don't want to use salt water (because of the clean up afterward)
you can hand wrap a bare metal wire around the insulated sections for testing, and ground this metal wire for the insulation test.
Magnecor brand are very good ignition wires,
last a long time before breakdown,
but are expensive:
http://www.magnecor.com/magnecor1/truth.htm
NGK wires are generally good,
and usually the best wire commonly available.
With the NGK you have to buy two 4 cyl sets for a V8, with the Subaru flat-4 engine wire kits generally having the longest wires.
