Page 11 of 13 1 2 9 10 11 12 13
Re: New 5.7 hemi eagle head [Re: MattW] #934497
06/26/12 12:25 AM
06/26/12 12:25 AM
Mesa, Arizona
az426hemi Offline
az426hemi  Offline
Mesa, Arizona
Has anyone built an Eagle headed engine?
If so how does it run?
What is your engine combo?
What chassis are you running?
Thanks,
Mike
Mike Firestine
mefirestine@yahoo.com
Re: New 5.7 hemi eagle head [Re: MattW] #934498
02/28/13 07:27 PM
02/28/13 07:27 PM
San Angelo, Texas
Cevidicus Offline
Cevidicus  Offline
San Angelo, Texas
did any one flow these new heads thanks
Just got my set flowed 5.7 stock head
intake ............. exhaust
.100 72.2 ............ 56.6
.200 150.4 ............ 112.4
.300 217.3 ............ 148.9
.400 272.5 ............ 176.3
.500 299.2 ............ 183.6
.600 302 ............ 185
not bad for a STOCK HEAD. Matt
Does anyone have any flow numbers from a set of Eagles that have been ported?
Re: New 5.7 hemi eagle head [Re: Cevidicus] #934499
03/02/13 11:37 AM
03/02/13 11:37 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
I THINK BES from the 2011 engines master challenge had a set that flowed to 360 cfm.
Don't know what bore size or type of maching was used.
I will bet that 330 to 340 would be easy with the eagle head.
Re: New 5.7 hemi eagle head [Re: MattW] #934500
12/30/13 03:33 PM
12/30/13 03:33 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Who has a part # for a complete factory 6.4 engine?
Re: New 5.7 hemi eagle head [Re: MattW] #934501
01/01/14 05:18 PM
01/01/14 05:18 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Re: New 5.7 hemi eagle head [Re: MattW] #934502
03/04/14 12:02 AM
03/04/14 12:02 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Re: New 5.7 hemi eagle head [Re: MattW] #934503
03/21/14 11:35 AM
03/21/14 11:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok I have a few questions.... what was the difference
between the 08 and the 09 engine... for some reason
I get the drift that the 08 is the better engine to
run as a carb engine.... the reason I ask is I would
like to build up a twin turbo gen 3... what parts are
interchangeable between the 08 and 09... or the 5.7
and the 6.1 .. also how do the bores stand up for wear..
I can pick up a 04 5.7 real cheap BUT it has 120K
on the odom.... any thoughts
Re: New 5.7 hemi eagle head [Re: MR_P_BODY] #934504
03/21/14 11:45 AM
03/21/14 11:45 AM
gregsdart Online content
gregsdart  Online Content
Mike, from what I hear the pre 09 blocks (5.7) have lots of meat in them for over bore and make an excellent base. For what ever reason, the local guru at Sharadon Performance still likes the early head for porting and power in a motor of about 420 or lss (not sure on the size, but big!) stroker. With a ported head flowing over 300 (320?) that would allow some serious steam with twin turbos. 400 cubes, 15 psi, 900 hp?
I am betting that is what could be had with 92 pump!
Re: New 5.7 hemi eagle head [Re: MR_P_BODY] #934505
03/21/14 11:48 AM
03/21/14 11:48 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
An 08 is a non VVT engine, same engine used from 03-08, an 09 is VVT, they use different cams which are not interchangeable. The 09 heads are better, probably 30-40 cfm better and are interchangeable. The cranks can physically interchange but the tone rings are different, not that u would use a stock crank with a turbo anyway. It sounds like the 04 block would be the one to use, more cam selection, and apparently the earlier blocks have better wall thickness. 120 K wouldn't be a huge worry, which modern rings and fuel injection the bores are probably fine
Re: New 5.7 hemi eagle head [Re: WO23Coronet] #934506
03/21/14 12:39 PM
03/21/14 12:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks guys..... next question... seems to be a few
09 engines out there... can the 09 with the VVT be
reworked to eliminate the VVT or is it just better
to get a pre 09... I'm looking for a complete engine
to start with
Re: New 5.7 hemi eagle head [Re: MR_P_BODY] #934507
03/21/14 02:03 PM
03/21/14 02:03 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Member Steff on here eliminated the VVT on his 6.4 build, but he used a custom belt drive and cam. Not sure if it could be done easier though. There are aftermarket VVT cams but they're pricey, $800 range pricey for just the cam, although, a 6.4 SRT cam is an upgrade alot of 5.7 guys do, and they can be had for less than $100. I imagine you could cut out the cam phaser and lock the timing where you want it, I'm guessing a lathe and mill would come in handy for this
Re: New 5.7 hemi eagle head [Re: WO23Coronet] #934508
03/21/14 03:05 PM
03/21/14 03:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have the lathe and mill.. that wouldnt be a problem
but is the block as strong on the 09 and up OR should
I continue on the path of the pre 09 engine(which
I think I might just do)
Re: New 5.7 hemi eagle head [Re: MR_P_BODY] #934509
03/21/14 03:59 PM
03/21/14 03:59 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Mopar to the bone!!!
Re: New 5.7 hemi eagle head [Re: MR_P_BODY] #934510
03/21/14 04:15 PM
03/21/14 04:15 PM
Chester, VA
tobnHisglory Offline
Chester, VA
I have owned 2 of the older 5.7 hemis, an 03 and 05. I currently have the Eagle motor in my 09 Ram. Neither of the older blocks had noticeable wear in the bore except one cylinder from a broken ring Even with nearly 100k on the block there was no ridge to be felt at the top. A block with 120k should be very serviceable.
Be careful on the overbore. Some of the early blocks were known to be "meaty" and some were very thin with noticeable core shift. With the kind of power you are wanting to build a sonic check is a must before you go any further.
-Reggie
tobnHisglory2000@aol.com
Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
Re: New 5.7 hemi eagle head [Re: tobnHisglory] #934511
03/21/14 06:44 PM
03/21/14 06:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks guys... I believe I'll go with the 5.7 that
has 120K on it... I'm
gonna tear it down anyways
Re: New 5.7 hemi eagle head [Re: MR_P_BODY] #934512
03/21/14 08:12 PM
03/21/14 08:12 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
https://board.moparts.org/ubbthreads/show...e=0&fpart=2
If anyone is interested, I've got some shots of my GTP ported eagle heads in the link above.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: New 5.7 hemi eagle head [Re: MR_P_BODY] #934513
03/21/14 09:28 PM
03/21/14 09:28 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
to start with
The vvt can be locked out using a cam lockout kit. Kind of pricey but simple enough to fab I think.
I personally think the earlier engine is the way to go. Cams are cheaper and some 5.7 blocks can take .080 over bore. Plus I believe the blocks have better material re hardness to them. They maybe thinner than the average LA block but stronger material and design. Matt
Re: New 5.7 hemi eagle head [Re: MattW] #934514
03/21/14 10:54 PM
03/21/14 10:54 PM
'murica
misfired Offline
misfired  Offline
'murica
I've got an 05 under my bench, 190k hone looks decent and NO ridge, I seriously couldn't believe it when I pulled the heads off but bad timing chain made valves bend
Re: New 5.7 hemi eagle head [Re: misfired] #934515
10/31/14 05:07 PM
10/31/14 05:07 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Re: New 5.7 hemi eagle head [Re: misfired] #934516
10/31/14 06:17 PM
10/31/14 06:17 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I've been saying for years, these motors wear really well.
