Re: New 5.7 hemi eagle head
[Re: MattW]
#934538
03/12/15 10:31 PM
03/12/15 10:31 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
.1 74 .2. 141 .3. 214 .4. 261 .5. 292 .6. 301
I like the eagle and apache head better.
So far I havnt been able to match my eagle head porting it but ive read the 6.1 is better but Im not sure. Im being conservitive though because their not mine
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#934539
03/12/15 11:33 PM
03/12/15 11:33 PM
sixpackgut
Charleston
Something I find completely perplexing is none of the gen 3 flow numbers that come from this site are even close to the numbers from the LX forums. All of ours are also always very similar, sometimes identical yet over there they are also very similar to each other from various vendors.
This is not the case when I go to the LS tech forums. I port alot of LS heads and every time my flow numbers are right in line with theirs. Even aftermarket. A TEA cnc square port flows 370, i get 370. AFR 225cc goes 325, on my bench the number are almost exact. Its always consistant
I called one of the hemi vendors that nobody likes, Inertia. He would not talk flow numbers and I know why, because all of the other hemi vendors are full of crap and I think he argues with them over there. Im not on there enough to know what the deal is though
[Re: mcat4321]
#934541
03/13/15 12:14 AM
03/13/15 12:14 AM
sixpackgut
Charleston
as some of you guy's know, i am fairly good friends with Tony Bischoff... yes, that Tony Bischoff, his favorite saying he probably uses every day..."you cant race a flow bench"
Your everyones friend
[Re: sixpackgut]
#934542
03/13/15 12:22 AM
03/13/15 12:22 AM
Posts: 8,306 fredericksburg,va
cudaman1969
fredericksburg,va
Do you have the hemi in that car? reason i'm going to use the same car got any photos?
[Re: sixpackgut]
#934544
03/13/15 12:48 AM
03/13/15 12:48 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Once i blow up this magnum motor or get my times I want on the race tune, I will be starting my Gen III hemi collecting. I want to go 6.4 block and apache heads with a BIG! turbo or maybe twins
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: sixpackgut]
#934546
03/13/15 04:01 AM
03/13/15 04:01 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
My cnc'd 6.1's don't have a lot of meat removed except guide transition and roof then some more on the short turn. Pretty conservative program it looks like.
Mopar to the bone!!!
[Re: sixpackgut]
#934548
03/13/15 10:38 AM
03/13/15 10:38 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Thx for sharing info
[Re: cudaman1969]
#934550
03/14/15 03:22 PM
03/14/15 03:22 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Ok i have read this entire article. questions 1. bore-stroke of the 5.7 2. bore-stroke of the 6.1 3. bore-stroke of the 6.4 if going to bore-stroke the engine, would the 5.7 be the least expensive(it will be in the car)? can the early heads on the 5.7 be ported to the size of the eagles? I'm confused on the cams working with the older vs new head? machined differently? My project was to find an older Challenger then install the 6.1 engine,($5200.00) now it looks like the 5.7 would could be made up just as well, later upgrade to the hellcat supercharger. This is all new to me so steer me right please.
1 3.92 x3.58 2 4.055x 3.58 3 4.090x 3.72 4 bore and stroke will be cheapest depending on which block is cheapest. yes don't know about finding a new 6,1. good luck and jump on it if you find one. Matt
"don't know about finding a new 6,1. good luck and jump on it if you find one"
can get a used one with 59,000 miles for $5200 out of a Charger with accessory's and boxes or one for $4,000 with 100,000 miles. maybe sell the 5.7
Nigel has 1 left. Less money than used.
http://nationalmoparts.com/lx-lc-parts?p...ategory_id=1839
Kevin
