Re: Torsion Bar 2" Drop Spindles ? [Re: TC@HP2] #934030
02/22/11 04:15 PM
02/22/11 04:15 PM
QLD Australia
Keith Black® Offline
QLD Australia
I'd definitely avoid the Fatman from a safety perspective. Get a one piece unit now that they're available.
Darren Beale
Keith Black Racing Engines®
Re: Torsion Bar 2" Drop Spindles ? [Re: Keith Black®] #934031
02/23/11 10:55 AM
02/23/11 10:55 AM
Fort Morgan
1OFNONE Offline OP
Has been a member for quite a few years, so relax.
1OFNONE  Offline OP
Fort Morgan
Any options out there for drum brakes?
So the bartender says to the horse " Gee, Why the long face?"
Re: Torsion Bar 2" Drop Spindles ? [Re: 1OFNONE] #934032
02/23/11 05:54 PM
02/23/11 05:54 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Never seen any thing for drum brakes.
From the looks of it, you could turn the t-bars down a bit more. You can get a couple inches out of that method before the rear starts to look funny for sticking up so high. You can get creative with bump stops to open up a little more room for movement as well.
Re: Torsion Bar 2" Drop Spindles ? [Re: Keith Black®] #934033
02/23/11 09:54 PM
02/23/11 09:54 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
That is a "One piece cast unit" Yes it probably is ductile iron, but can never compare to the factory forged units. I agree that the weight savings would be well worth it. But as far as strength, I doubt their is anything worth comparing. For those of you who already have either of these spindles....Run'Em....A properly executed weld joint is as strong as the parent metal.
Re: Torsion Bar 2" Drop Spindles ? [Re: Bill MeLater] #934034
02/23/11 10:24 PM
02/23/11 10:24 PM
QLD Australia
QLD Australia
Mopar Action (Apr '11) did a test on the drop spindles, the MF unit, although cast is very strong. Unable to pass tech & engineering to get vehicle registration (& insurance) with welded spindles here in Australia. probably for a reason.
Darren Beale
Re: Torsion Bar 2" Drop Spindles ? [Re: Keith Black®] #934035
02/24/11 01:33 AM
02/24/11 01:33 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Sounds like Calif and Australia are lot closer then I thought.
And I agree on the comment on a proper weld strenght. And "probably for a reason" is not always the reason one would hope for, but ignorance is bliss. Read the XV thread and just grind the welds smooth, beadblast the spindle, and tell the inspectors if they ask its a custom shotpeened billet spindle. So whats next, non welded steel wheels?
Re: Torsion Bar 2" Drop Spindles ? [Re: jcc] #934036
02/24/11 06:28 AM
02/24/11 06:28 AM
QLD Australia
QLD Australia
Darren Beale
Re: Torsion Bar 2" Drop Spindles ? [Re: Keith Black®] #934037
02/24/11 12:29 PM
02/24/11 12:29 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
And the "reason" is probably a lot closer to it being a law passed by uninformed government bueacrats than any actual research.
Re: Torsion Bar 2" Drop Spindles ? [Re: TC@HP2] #934038
02/24/11 04:30 PM
02/24/11 04:30 PM
QLD Australia
QLD Australia
Yep.
and also the engineers who have to certify the cars don't want to be sued by insurance companies if there's a failure. despite what your may believe Australia is worse in terms of litigation than Cali I reckon.
Darren Beale
Re: Torsion Bar 2" Drop Spindles ? [Re: Keith Black®] #934039
02/24/11 11:55 PM
02/24/11 11:55 PM
Wisconsin USA
Wisconsin USA
Yep.
Ya'll use the term "I reckon" down there or are you just funnin'?
Re: Torsion Bar 2" Drop Spindles ? [Re: Bill MeLater] #934040
02/25/11 12:48 AM
02/25/11 12:48 AM
QLD Australia
QLD Australia
..we use it !
Darren Beale
Re: Torsion Bar 2" Drop Spindles ? [Re: Keith Black®] #934041
02/25/11 01:42 AM
02/25/11 01:42 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Yep.
Should see the amount of records kept for vehicles done through the RAWS setup... for the 2010 Camaros we did, there is a a huge binder full of info with pictures and specs on every single change done to the car
I know another guy who is an engineer too (around Melbourne), and he has specs and info on tons of stuff that they check and record for modified older cars (like all the stuff you have been doing.)
Re: Torsion Bar 2" Drop Spindles ? [Re: Keith Black®] #934042
02/26/11 12:23 AM
02/26/11 12:23 AM
Wisconsin USA
Wisconsin USA
..we use it !
Right on! You Guy's gotta have your $hit together to run Mopars down there.....
