Quick ignition question #933794
02/21/11 07:39 AM
02/21/11 07:39 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
With a stock single point dizzy, does the wire from the dizzy go to the negative or the positive side of the coil
thanks
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Quick ignition question [Re: roe] #933795
02/21/11 08:36 AM
02/21/11 08:36 AM
scratchnfotraction Offline
black wire from points will go on the negitive side of coil
Re: Quick ignition question [Re: scratchnfotraction] #933796
02/21/11 08:46 AM
02/21/11 08:46 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Re: Quick ignition question [Re: roe] #933797
02/21/11 08:54 AM
02/21/11 08:54 AM
if you have a tach the green wire will go on the negitive side also
