While installing new shocks & correct bushings, I ran into a small issue. On one set of the correct NOS bushings the inner steel sleeve would not fit onto my shock. The other set did fit as this sleeve had a split in the sleeve. Does anyone sell just the inner steel sleeve with the split in it ? Thanks!
