Re: Adjusting Shifter rods and levers on 4speed.
[Re: Blakcharger440]
#933066
02/20/11 02:36 PM
02/20/11 02:36 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Disconnect the rods from either the tranny or shifter before inserting a 1/4" dia rod into the alignment hole on the shifter arms, that will allow you to align all 3 arms together,....chances are you also have shifter stops on the shifter body, perhaps those are misadjusted also, back them out when performing the netural shifter adjustment
Mike
I already did that...like I said my alignment tool will only go through 1/2 and 3/4 so it does align those two levers but it doesnt even pass through the reverse shifter lever in order to get that one in alignment also...in other words it only aligns 2 arms.
I have an extra Hurst shifter on my bench top and it is the same way. Does the reverse shift lever not have to be aligned?
It goes through all three arms on the factory shifters. Can you see the hole on the reverse arm?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#933067
02/20/11 03:17 PM
02/20/11 03:17 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I have a Hurst Comp shifter on one of my cars, a shifter alignment tool (1/4" dowel) goes thru all 3 arms as well
#933068
02/20/11 04:09 PM
02/20/11 04:09 PM
Posts: 5,445 So Cal
Sinitro
So Cal
The later Competition + aftermarket gates only have the alignment holes in the 1/2 & 3/4 arms not the reverse... Don't know why but I have (3) Hurst gates and they are all this way. So what I do is set the 1/2 & 3/4 arms using a small drill through the holes. Then eyeball the reverse arm.. EZ to tell when all arms are aligned properly in neutral, the shifter lever will move easily left to right.. Just my $0.02..
[Re: Sinitro]
#933070
02/20/11 05:00 PM
02/20/11 05:00 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
Just my $0.02..
Yep thats what I thought. I had to eyeball the reverse arm alignment as well.
I aligned it and just got back from a short drive. It is alot better but somehow I think it should be even better.
[Re: fourgearsavoy]
#933071
02/20/11 05:02 PM
02/20/11 05:02 PM
Blakcharger440
Wichita,KS
Just my $0.02..
I have also seen other Hurst shifters without the hole in the reverse lever Make sure your side cover is pushed as far up as it will go Gus
Side cover????
#933072
02/20/11 05:06 PM
02/20/11 05:06 PM
Posts: 21,837 Kirkland, Washington
Pacnorthcuda
Just my $0.02..
Side cover????
The main cover on the side of the tranny where the forks/rods attach. The cover has a little up-down play in it before you cinch it down. If you tighten it in the 'lower' position the reverse cam can bind against the shift fork above it---makes getting it in and out of reverse very hard. Loosen it up and tap the cover up a skosh and you will have plenty of clearance.
