Page 5 of 5 1 2 3 4 5
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932713
04/06/11 05:24 PM
04/06/11 05:24 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Ok, here you go, mystery not solved...
"Looking at the 3 pictures you sent, I don't recall any cast aluminum parts we did in production. These look like just like the sheet metal parts made in production by Canadian Fram in Chatham Ontario, but if these really are cast aluminum, someone made them based on the production parts. This would be a lot of effort.
Even has the two-hole mounting boss for the heated air temp sensor used on the production part.
And, I'd be surprised if these parts weighed any less than the steel pieces. Why don't you check...
You need to get in touch with an old Dodge/Plymouth factory drag racer who was involved during the early '70s. How about someone from the Sox & Martin race team?"
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: NicksGarage] #932714
04/06/11 07:02 PM
04/06/11 07:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
There was a heated sensor on the AIR GRABBER Air cleaner ???? Never seen one with one , no need for it it's not like it have a heat stove like the other models that year ?
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: JohnRR] #932715
04/09/11 10:08 AM
04/09/11 10:08 AM
WI
W
wannadrag Offline OP
W
WI
Back up
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932716
04/15/11 08:08 PM
04/15/11 08:08 PM
WI
W
W
WI
Again
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932717
04/15/11 08:53 PM
04/15/11 08:53 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Magazine Road Test Ringer...............bet if you found the test car it was on that's not the only light weight item you'd find
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: A12] #932718
04/16/11 10:39 AM
04/16/11 10:39 AM
WI
W
W
WI
If it helps i was told the car spent its entire life in eastern WI.The previous 2 owners had the car for around 15 years.The air grabber came with it and they know nothing about it.So its been with the car for some time.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: A12] #932719
04/16/11 12:09 PM
04/16/11 12:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
With this in mind have you actually weighed the base and the top ?
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: JohnRR] #932720
04/16/11 12:54 PM
04/16/11 12:54 PM
Kirkland, Washington
Pacnorthcuda Offline
The OP posted:
"Yes aluminum and pretty heavy.When i looked at the car it was laying in the back seat and i just assumed it was a painted tin one till i got the car home and looked closer. "
This item's original purpose has NOTHING to do with weight-savings.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: Pacnorthcuda] #932721
04/20/11 08:08 PM
04/20/11 08:08 PM
WI
W
W
WI
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932722
05/07/11 11:11 AM
05/07/11 11:11 AM
WI
W
W
WI
bump
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932723
05/07/11 11:31 AM
05/07/11 11:31 AM
Washougal,Wa
Dodge Offline
Dodge  Offline
Washougal,Wa
Stand behind your word
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: Dodge] #932724
05/09/11 09:26 AM
05/09/11 09:26 AM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: migsBIG] #932725
05/10/11 03:04 AM
05/10/11 03:04 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
This has got to be the bumpiest thread I ever did see.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: NicksGarage] #932726
05/10/11 03:13 AM
05/10/11 03:13 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Bumpy yes but really an interesting piece... I think everyone would really like to know the story....
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: 1_WILD_RT] #932727
05/14/11 11:21 PM
05/14/11 11:21 PM
WI
W
W
WI
Me too
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932728
07/26/11 10:01 PM
07/26/11 10:01 PM
WI
W
W
WI
bumpity bump
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932729
07/26/11 10:26 PM
07/26/11 10:26 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, this doesn't really add to the info on the cast air cleaner setup but it's a related post anyway.
This is an aluminum Shaker Hood Adapter Ring, it's exactly like an original but lacks the welded in drain tubes, etc. The outer lip is rolled the same way as the steel versions. I bought it from a friend who does not know where it originated. It's possible that it was a factory part made from the original molds, or made in one of the 2 reproduction molds that I know of (Gene Gregory or Ben Snobars) I can't say. But one thing's for sure, it's cool! Domingo found one years ago on ebay (may have been the base plate, I forget?) so I'm pretty sure others exist, just never see them.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: ScottSmith_Harms] #932730
07/26/11 10:26 PM
07/26/11 10:26 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
underside
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: ScottSmith_Harms] #932731
07/27/11 08:14 AM
07/27/11 08:14 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Cool piece Scott. I doubt it is a factory piece because they had the seven outer 7/16 inch stamped holes to accomodate the seven chamfered nuts that were welded on. Both Geans' and Bens' have the smaller 3/16 inch holes, as yours appears to have.
Neither repro use these correct nuts, plus there are other telltale signs between repro and real.
Maybe I'm seeing your picture wrong but the holes look smaller.
Let us know.
