Page 1 of 5 1 2 3 4 5
Air grabber air cleaner base and top????Cast aluminum?? #932633
02/19/11 11:01 PM
02/19/11 11:01 PM
WI
W
wannadrag Offline OP
W
WI
Were the originals aluminum?I picked up a car today that came with one for a single carb,cast aluminum base and top.Need to know what its from?
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932634
02/20/11 12:45 AM
02/20/11 12:45 AM
Gateway to the West.
hemi_harvester Offline
NO.They were stamped steel...
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932635
02/20/11 03:06 AM
02/20/11 03:06 AM
wisconsin united states
K
keith airgrabber Offline
Right in the Nutz!!!
K
Wanna sell it ? I have never heard of this. You might have a factory proto-type or something. That's why I love mopar. You never know what kind of weird stuff will pop up next.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: keith airgrabber] #932636
02/20/11 10:28 AM
02/20/11 10:28 AM
Please post MORE pictures any numbers or anything cast on it ?
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: hemi_harvester] #932637
02/20/11 12:52 PM
02/20/11 12:52 PM
WI
W
W
WI
No numbers or markings cast into it,just some writing with a paint stick on the bottom do not touch.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932638
02/20/11 01:07 PM
02/20/11 01:07 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
That is REALLY cool! Not to ask a stupid question but are you SURE its aluminum???
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: Pacnorthcuda] #932639
02/20/11 01:13 PM
02/20/11 01:13 PM
WI
W
W
WI
Yes aluminum and pretty heavy.When i looked at the car it was laying in the back seat and i just assumed it was a painted tin one till i got the car home and looked closer.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932640
02/20/11 01:16 PM
02/20/11 01:16 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Put a magnet on it, and see if it sticks.
My is you have a bead cleaned upper & lower.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: hemi71x] #932641
02/20/11 01:37 PM
02/20/11 01:37 PM
WI
W
W
WI
Magnet does not stick and it is a cast type aluminum.I just looked again and no markings whatsoever.What you see is polished aluminum.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932642
02/20/11 02:01 PM
02/20/11 02:01 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
I'd say you got a repop that's not such a "pro-re"
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: Yancy Derringer] #932643
02/20/11 04:36 PM
02/20/11 04:36 PM
WI
W
W
WI
Ok,i guess nothing to special so i will paint it and use it.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932644
02/20/11 04:46 PM
02/20/11 04:46 PM
Brantford Ontario
69_SIX_PACK Offline
69_SIX_PACK  Offline
Brantford Ontario
Could you post a bigger picture of the base with no lid and filter?
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: 69_SIX_PACK] #932645
02/20/11 05:37 PM
02/20/11 05:37 PM
WI
W
W
WI
pics
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932646
02/20/11 05:40 PM
02/20/11 05:40 PM
WI
W
W
WI
another
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932647
02/20/11 06:53 PM
02/20/11 06:53 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I don't know what it is but I'd say it's a factory prototype or something of that nature... Far to well made for a home effort, & if it's a repo then I'd think there would be more of them floating around....
Interesting piece....
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: 1_WILD_RT] #932648
02/20/11 10:18 PM
02/20/11 10:18 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I wouldn't be in a big hurry to paint it and use it right away until a little more investigating.
Any chance you can get a close-up of the bridge ( the top bracket ) and how it is connected to the base.
Original steel ones were spotwelded which cannot be the case here.
Is that an aluminum weld on the rear passenger side and again on the rear corner.
Thanks in advance
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: mccannix] #932649
02/20/11 10:22 PM
02/20/11 10:22 PM
WI
W
W
WI
Yep that is a weld on the corner and the bridge is the same material as the rest of it and is welded to the base.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: mccannix] #932650
02/20/11 11:22 PM
02/20/11 11:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: DAYCLONA] #932651
02/20/11 11:38 PM
02/20/11 11:38 PM
WI
W
W
WI
Will do till you guys figure out what i have.
Re: Air grabber air cleaner base and top????Cast aluminum?? [Re: wannadrag] #932652
02/21/11 01:47 AM
02/21/11 01:47 AM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
That's pretty neat. Never seen anything like it.
