Re: Correct caliper position
[Re: 4404dart]
#932595
02/19/11 09:32 PM
02/19/11 09:32 PM
RapidRobert
Yes you'd need a caliper w the bleeder on top maybe an F body app & best is to have the caliper on the opposite side that the hardline/flex hose tab is on which for you would be to have the calipers in the front. As is you'd want to check the hose from lock to lock & get a diff or a custom hose if any probs there but that particular caliper will not ever bleed out in that position. Do you have a front sway bar & that's why you went rear mount? Was a post on lengthening or shortening sway bar links I forget which to allow front calipers w a sway bar
[Re: 4404dart]
#932596
02/19/11 09:32 PM
02/19/11 09:32 PM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
NO, caliper is on the wrong side
Bleeder needs to be at top, and the whole set up does work better for brake line routing if the caliper is in front and line runs between the ball joints. Like the car that that set up came off of.
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
