70 charger steering column removal #932287
02/19/11 01:12 PM
02/19/11 01:12 PM
louisiana
mopar70charger Offline OP
louisiana
can someone tell me exactly how to remove the shaft from the gearbox on my 70 charger. i have it all disconnected elsewhere but cant seem to remove it from the gearbox , not so sure ..thanks
Re: 70 charger steering column removal [Re: mopar70charger] #932288
02/19/11 05:28 PM
02/19/11 05:28 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
There is a split hollow dowel that goes through the shaft & steering coupler that you have to drive out. Look for a bout a 3/16 dia hole near the end of the shaft. The pin is inside this hole. Use a punch and a hammer to drive it out. PS - it will only come out in one direction if I remember right. So do not beat it too death!!!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 charger steering column removal [Re: mopar70charger] #932289
02/19/11 07:37 PM
02/19/11 07:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
do just as Joe mentioned above,...here's a pic of where to place the punch,....remember the pin has a taper to it,..only goes in one way, look for the smallest diameter of the pin end to punch on with a drift to remove it,...they can be stubborn
Re: 70 charger steering column removal [Re: 70gtx440dana] #932290
02/19/11 07:38 PM
02/19/11 07:38 PM
bc
3
37dodge Offline
37dodge  Offline
bc
this might help
Re: 70 charger steering column removal [Re: 37dodge] #932291
02/20/11 02:13 PM
02/20/11 02:13 PM
louisiana
louisiana
thank you guys for all the help. i think i can handle it now...later , joe
