Commpression #932152
02/19/11 02:04 AM
02/19/11 02:04 AM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
I have tryed to figure out how to use those online CR formulas with no luck, can someone give me a figure on my CR with these componets,440 bored 30 over 4.350, stock deck height using stock length H beam rods,6.768 with Ross 99501 dome pistons,2v/v relieves,comp dist 1.273,dome height 0.640, piston head volume -50cc, comp height 2.065, dome volume -14cc.On top is a set of stock Stealth Heads with a .040 head gasket,also cam is Comp 284H with Crane 1/6 roller rockers with a lift of 541 in and 544 ex intake opens at 36 BTDC and closes 68 ABDC, EX opens 82 BBDC and closes 34 ATDC, Duration @.50 In 240, Ex 246,Valve timing 0.006 Lobe center 110,intake centerline 106 Thanks very much for any info, Rodger
Re: Commpression [Re: 69 GTX] #932153
02/19/11 02:52 AM
02/19/11 02:52 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Some of your things do not compute , first off there is no H beam rod that is STOCK length , all except for a manely which is not available anymore, are 6.760 .
Then your piston volumes, -50 and a dome of -14 ???? A dome with a NEGATIVE volume is a DISH
Compression distance of 1.273 but a compression height of 2.065 ????
No wonder you can't figure out your compression ratio
edit ... i goofed the rod length , damm dyslexia
Re: Commpression [Re: JohnRR] #932154
02/19/11 12:04 PM
02/19/11 12:04 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
No stock length H beam rods better tell eagle
http://chucker54.stores.yahoo.net/corodse1.html
Re: Commpression [Re: 69 GTX] #932155
02/19/11 12:11 PM
02/19/11 12:11 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
So you have a 2.065 compression height piston with a 14 cc dome and stealth heads in a + .030 440 with a .040 gasket.
You compression will be about 12.5 to 1
Stroke 3.75
deck 0 deck
Dome - 14 cc
Head 83 cc average
gasket .040 average about 10 CC
Displaces 913 cc per cylinder
effective volume 83 + 10 - 14 = 79
913 + 79/79 = 12.55 to 1
Re: Commpression [Re: 69 GTX] #932156
02/19/11 12:14 PM
02/19/11 12:14 PM
Rodger get the correct specs & plug em in & see what you really have & head CC's and deck height figures you really need to measure what you actually have as listed specs are not accurate. The KB calculator is simple/accurate for SCR but to add in your cam specs etc for DCR you'd want a diff calculator (not sure which one, maybe Wallace racing ones which have been mentioned on here)
Re: Commpression [Re: 69 GTX] #932157
02/19/11 02:16 PM
02/19/11 02:16 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Your dynamic compression ratio is 10.95 :1 corrected for cam timing, altitude, and rod length. Your dynamic cranking pressure, corrected for cam timing, rod length and altitude is 237.43 PSI.
not knowing where you live I used 1000 feet actual altitude
Why did you go such high compression???
Re: Commpression [Re: 69 GTX] #932158
02/19/11 02:17 PM
02/19/11 02:17 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
your intake closing is 46 ABDC
boost is 0
http://www.rbracing-rsr.com/comprAdvHD.htm
Re: Commpression [Re: Dodgem] #932159
02/19/11 06:39 PM
02/19/11 06:39 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Stroke 3.75
deck 0 deck
Dome - 14 cc
Head 83 cc average
Is your presumption that "stock deck height" is the same a bluprinted deck height?, verses factory actual deck height?
Re: Commpression [Re: Dodgem] #932160
02/19/11 08:02 PM
02/19/11 08:02 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Those rods are listed at 6.760...I believe stock length is 6.768. It's only .008 but i went through that when I did my low deck stroker,got some of the last Manleys that are a true 6.768 rod as JohnRR said.
Re: Commpression [Re: Dodgem] #932161
02/20/11 04:24 PM
02/20/11 04:24 PM
U.S.S.A.
U.S.S.A.
Maybe you should contact your optometrist because you obviously can NOT read what's written there. A STOCK length RB rod is 6.768 the Eagle , as are most ALL aftermarket rods , are 6.760.
Re: Commpression [Re: Dcuda69] #932162
02/20/11 04:27 PM
02/20/11 04:27 PM
U.S.S.A.
U.S.S.A.
It may be only .008 but it starts to add up once you start adding in other market parts that are shorter than factory , the shorter rod and a piston that is already .020 in the hole is now .028 , if you are trying to build a quench engine you are now .008 further away ....
The Manleys that were available were 6.765 , which is closer but ...
Re: Commpression [Re: BSB67] #932163
02/20/11 04:33 PM
02/20/11 04:33 PM
U.S.S.A.
U.S.S.A.
Stroke 3.75
deck 0 deck
Dome - 14 cc
Head 83 cc average
Is your presumption that "stock deck height" is the same a blueprinted deck height?, verses factory actual deck height?
Nevermind that he can't read he can't add either , a 2.065 piston on a 6.768 rod in a 10.725 factory deck is .017 IN THE HOLE , put it on his shorter 6.760 rod and now it's .025 in the hole .
Or is that zero deck when you convert from metric to decimal ???
Using the above specs, 6.760 rod I get 11.59
Re: Commpression [Re: JohnRR] #932164
02/21/11 01:32 PM
02/21/11 01:32 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Some of you guys are way to anal!
.008 really blueprint really.
Yes it was a generalization of being within spec.
Short of actual ccing which i doubt you guys have the equipment to do to be exact it does end up ballpark.
Re: Commpression [Re: Dodgem] #932165
02/21/11 02:28 PM
02/21/11 02:28 PM
U.S.S.A.
U.S.S.A.
.025 in the hole is more like grand canyon than ballpark ...
I'll post up a pic of my burret later for you if you'd like .
Re: Commpression [Re: Dodgem] #932166
02/21/11 02:45 PM
02/21/11 02:45 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
237 psi can't be correct.
Re: Commpression [Re: 64Post] #932167
02/21/11 03:39 PM
02/21/11 03:39 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
well if you go to the low side of tolerances 225 tat 12 to 1 with that cam piston has a 14cc dome
Re: Commpression [Re: Dodgem] #932168
02/21/11 04:02 PM
02/21/11 04:02 PM
U.S.S.A.
U.S.S.A.
It has a 14 cc dome but does that also include the valve reliefs ? If it does that's closer to a 20cc dome, which is pretty big .
Re: Commpression [Re: Dodgem] #932169
02/21/11 05:37 PM
02/21/11 05:37 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I came up with 200 PSi cranking and 9.57 dynamic @ 100 ft. elevation. DCR will decrease with altitude.
Also, the dome is irrelevant when calculating DCR.
Re: Commpression [Re: 64Post] #932170
02/22/11 03:02 PM
02/22/11 03:02 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Normally a piston spec includes the valve notch so a -14 cc dome is gross just as a + 14 cc dish would include the valve notches in that number.
This calculator uses @.050 numbers on the calculation so a 240 at .050 intake lobe is 240/2 = 120 then the install is 106 so 74 deg remain to bdc you take the remaining 120 deg and subtracted the 74 from it leaving 46 degrees @.050 ABDC boost is 0.
It gives me 225 and 10.5
This calculator has been withing 7 to 8 lb actual average cranking compression on my last three motors and numerous friends motors.
Re: Commpression [Re: Dodgem] #932171
02/22/11 04:29 PM
02/22/11 04:29 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
OK. I use this one: http://www.wallaceracing.com/dynamic-cr.php
Arguably, I use the more accurate .006" TE numbers from the cam card http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=709&sb=2
