Page 2 of 6 1 2 3 4 5 6
Re: Shock Tech [Re: joshking440] #931988
02/19/11 12:54 AM
02/19/11 12:54 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
My car separates real bad because my afco shocks can't take the horsepower...... Eric, weren't you gonna call me back
man c'mon! You have a 1300HP 9.0 car... i'd blame it on the shocks also
Mopar Performance
Re: Shock Tech [Re: HEMIFRED] #931989
02/19/11 01:08 AM
02/19/11 01:08 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
I would like to know the difference in shocks, how they work, what makes one better than another, how effective the different types are etc
same here what is so different about the valving used by Santhuff as opposed to most other brands. What are the negatives of using them other than the outrageous costs.
On those notes... What about how to look a shock dyno sheet a little and what to choose for your application. Like when to choose progressive, digressive, or linear shocks. Or what you want your Force vs. Velocity and Force vs. Displacement graphs to look like.
It's like, OK that what the graphs represent but what should I shoot for? How do you apply that info?
Maybe sort of like this but more specific to the application: http://www.circletrack.com/techarticles/shock_absorber_shock_dyno/index.html
Even a little like this very good read and info: http://www.nttyres.com/downloads/guide_to_dyno_graphs.pdf
Anyone want to build their own shock dyno?: http://www.circletrack.com/howto/82884_buildling_shock_dyno/index.html
Re: Shock Tech [Re: moparniac] #931990
02/19/11 01:17 AM
02/19/11 01:17 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I can't wait.....
Re: Shock Tech #931991
02/19/11 01:33 AM
02/19/11 01:33 AM
IN
E
EricatAFCO Offline OP
E
IN
Spring rate is very important...if the rear spring rate is too stiff, the car won't rotate properly. No shock will soften up enough. If the front end is dead, the car won't work as well as it can. If the bars have been in the car for a long time, they may need to be replaced. Both ends have to work together. Pinion angle is another variable that is in play. So, in your example as in most, there doesn't seem to be one answer...we have to plan the work and work the plan, one step at the time.
Re: Shock Tech [Re: CHAPPER] #931992
02/19/11 01:33 AM
02/19/11 01:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I can see this is going to get confusing,,,it's like everybody is talking at once. Maybe,,try to answer one question at a time, and other posters have patience and just read and try to see if the questions posted are similar to their problems and learn from them...I hope Eric is ready for LOTS of PM's ...
No... no reason for that.... if Eric wants to answer
YOUR question all he needs to do is click on YOUR
post as a reply OR click on YOUR QUOTE and then
answer the question.... a LOT of guys just click
on the last post in line and in that case you wouldnt
know who your talking to.... by rights you would be
talking to the poster you clicked on.... so I WISH
the guys would catch on to post correctly
EDIT
I should say also that if he clicks on YOUR post as
REPLY it will have YOUR name on the top of the post
so look at the name on the post he is replying to
just to make sure you are reading the stuff that was
directed to YOU ...... hope that makes it clear to
ALL on the posting
Thanks..... also this has a sticky dont expect
the guy to JUMP when you ask a question... I'm sure
he has a JOB and a family.... its not going anywhere
Re: Shock Tech [Re: joshking440] #931993
02/19/11 01:58 AM
02/19/11 01:58 AM
IN
E
E
IN
I can't wait.....
Could be the driver running out of talent?
Re: Shock Tech [Re: EricatAFCO] #931994
02/19/11 02:02 AM
02/19/11 02:02 AM
USA
Slider Offline
super gas
Slider  Offline
super gas
USA
Oooo, this could be good!!
�Hunt down those Chevies and Fords and crush �em like bugs!� ~ Tom Hoover
(O=o=====o=O)
Re: Shock Tech [Re: moderncylinder] #931995
02/19/11 02:09 AM
02/19/11 02:09 AM
IN
E
E
IN
ive always been told you run compression tight and extension loose,,, when starting off would you run in the middle of your adjustments or bias it one way or the other? how about compression 1/4 way between, bias toward being hard,, and ext in the middle?? or???
Many factors determine where to start. The lower HP applications should begin on the soft end of the range. Keeping in mind that we need to control the rear tire, I usually work the rebound first. Start out soft and keep feeding more rebound into the car watching to see when performance begins to drop off. Compression can be used to control down track "wander" or again to prevent the basketball effect just off the line. I haven't been one to simply say to start in the middle...It may take a few runs to determine how much is too much.
Re: Shock Tech [Re: EricatAFCO] #931996
02/19/11 02:17 AM
02/19/11 02:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Eric maybe you should clarify some of the terms
you will be using just for a base line so everyone
understands... I know I use terms like rebound and
compression but others use extension .... I also
use the term jounce and rebound but others dont seem
to use jounce(this is from when I worked in the
suspension lab at Chrysler
Re: Shock Tech [Re: greendart408] #931997
02/19/11 02:17 AM
02/19/11 02:17 AM
IN
E
E
IN
I have been having this issue for awhile now. Car initially hooks then spins bad....I have had my double adj shocks all over with the adjustments and nothing seems to work at all. Have had 3 diff rear springs on it as well 150, 130, and now currently. 110s. Made no change. I run ladder bars. Im thinking I need a stiff sidewall tire. I run a 29.5x11.5 mt. Car runs mid to upper 1.3 s and 9.60s and weighs 3100. Should be in the high 1.2s. I feel with my alky injection. Any suggestions? Thanks for your time.
We want to spring the car as softly as possible without causing the spring to bow. The softer choice should provide the most consistent performance given multiple track conditions... If your car weights 3100 and is something like 55% front, 45% rear or so, The 110#'s should be ok, again as long as they aren't hitting the springs..
Ladder bar cars usually respond well to a fair amount of pinion angle. I have seen cars go from not trying to work with 2-3 degrees to hanging the front end with 5 degrees. Again, the front end has to work too. If it is dead, we may not get maximum performance out of the car. Also, we have to make sure we are bind free...
Re: Shock Tech [Re: EricatAFCO] #931998
02/19/11 02:18 AM
02/19/11 02:18 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I can't wait.....
Just have to add to that one
Eric, I have a feeling your gonna fit right in here
I hope to learn a lot from this thread.
Re: Shock Tech [Re: cheapstreetdustr] #931999
02/19/11 02:19 AM
02/19/11 02:19 AM
IN
E
E
IN
Eric i dont know how intimate you are with Mopars specifically.
there are some factors that are different when diagnosing mopar type leaf sprung rear suspensions. the short front spring half is a factor. just to bring this to light not judge anyones knowledge..
i just want to put this out there..
If we are talking about mopar leaf sprung rear suspensions..
then proper rear shackle movement is a necessity to eleviate rear spring bind..in the extension of rear suspension travel..its a common problem for mopars...so is too short a shock itself..
these are both huge contributors to porpousing ..ie..hook unhook/unload..hook on a leafspring drag car..
as you can see i am passionate about this..
i am no expert...just someone who doesnt mind jumping in...ive helped fix this with a bunch of mopars...and some of it is ubiquitous in our world.
have at it..
cheapst..
and again Welcome...I am all ears..
Cheap,
Thanks for the input....we all will learn something
Re: Shock Tech [Re: fourgearsavoy] #932000
02/19/11 02:23 AM
02/19/11 02:23 AM
IN
E
E
IN
Well I have recently changed shocks from Pro-Comp truck shocks to the Rancho XL9000 series adjustable socks and have noticed a positive change.
My tires used to unload after the hit and wad up before they spun producing a very poor 1.7 60' time
Now since installing the Rancho shocks I have cut my 60' down to 1.41 on a marginal starting line.
The good shocks took the bounce out of the rear end and I am happy now and can see mid ten second ET's on the horizon
Gus
Four,
You are on the right track. The more gear, more torque and HP, the more control you will need from your shock. (If you go from a foot brake launch to trans brake, more shock control will be needed too) Also, if we don't step away from what we know and try something else, how do we know how much performance is still in there?
Re: Shock Tech [Re: EricatAFCO] #932001
02/19/11 02:31 AM
02/19/11 02:31 AM
So Cal
So Cal
Looking at a Road Race application on a 1968 Barracuda.…
Spring package:
350 lbs/in calculated at the ball joint wheel rate front springs (1.14” t-bars). 1.25” hollow sway bar
140 lbs/in rear leaf springs (sort of guessing at that +/-10 lbs). 3/4 “ sway bar that is adjustable
Computer wheel weight scale sheet as follows:
LF..987 RF..924
LR..731 RR..770
56% front weight bias
3412 lbs total weight
108 wheel base
Should I be looking at progressive, digressive, or linear shocks?
What kind of shock rates should I be looking at to control those springs in this application?
Do I need to get more info to make a better choice? If so what?
Re: Shock Tech [Re: MR_P_BODY] #932002
02/19/11 02:31 AM
02/19/11 02:31 AM
IN
E
E
IN
Mr P, good point. Compression and jounce are the shock compressing-coming together. Rebound/extension is the shock pulling apart. I will try to use compresson and extension as the baseline...sometimes I find that the term, "rebound" slips out where I mean extension.
Re: Shock Tech [Re: EricatAFCO] #932003
02/19/11 02:35 AM
02/19/11 02:35 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
can you explain how pinion angle has an effect on how a suspension acts?
Re: Shock Tech [Re: autoxcuda] #932004
02/19/11 02:55 AM
02/19/11 02:55 AM
IN
E
E
IN
Spring package:
140 lbs/in rear leaf springs (sort of guessing at that). 3/4 “ sway bar that is adjustable
LF..987 RF..924
LR..731 RR..770
108 wheel base
We have seen positive results in applying linear valving in autocross applications. The harder you charge the corners, the sticker the tires and the heavier the car, the more you will find the linear stuff to your liking...
As far as shock rates go, the variables are vast. Shock rates go up as shock speed increases. (On the shock dyno, if you run the shock at 6 inches per second, record the dampening rate, then spin that shock at 10 IPS, the shock will be stiffer given the same valving or setting). The shock rate does work to control the springs but also helps to control body roll...The higher the center of gravity, the harder you drive, tigher the corners etc, the stiffer the shocks need to be...
In your case, adjustable shocks would be a wise investment. One idea is to tune the shocks to your liking-performance is maximized and then getting the shocks dynoed. From there, you will have a baseline. Two things come from this exercise. One, you now have a file of each shock in case of damage and need for repair. Two, you can map where you are, see how much a click change makes in pounds of force (in the shock)and get an idea of how much the shock change will help you dial in the chassis. Gotta know how much to change something. Also, this could reduce the risk of tuning past the sweet spot when making a guess without hard data to support the tuning choice.
Re: Shock Tech [Re: EricatAFCO] #932005
02/19/11 03:14 AM
02/19/11 03:14 AM
So Cal
So Cal
Spring package:
LF..987 RF..924
LR..731 RR..770
108 wheel base
Would you suggest linear valving also for this car in a Road Race application (Willow Springs) vs autocross?
What IPS rate do you guys use for your shocks? I've heard different companies use different rates, so it's tough to compare sometimes.
What kind of rate range at given IPS of adjustable shocks should I be looking for? Like what adjustable Afco shock would you recommend?
What about a non adjustable shock starting point? I may be able to adapt circle track shocks.
I can get shocks dyno'd. I help with a www.RacecarFactory.com (Jeff Schrader) big late model team out at Irwindale. The team has a dyno.
Re: Shock Tech [Re: sixpackgut] #932006
02/19/11 09:23 AM
02/19/11 09:23 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
lolz here we go
Mopar Performance
Re: Shock Tech [Re: EricatAFCO] #932007
02/19/11 09:31 AM
02/19/11 09:31 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I can't wait.....
I bought a pair of the AFCO DA's and have yet to try them out! I saw how much they made a difference on my buddies camaro with NO other changes... he used the intital setting used in the directions and went from 4-6" wheeelie to about a 12" wheelie carrying it out 10ft or so! I cant wait to try mine out either!
Mopar Performance
