Page 1 of 6 1 2 3 4 5 6
Shock Tech #931968
02/18/11 07:49 PM
02/18/11 07:49 PM
IN
E
EricatAFCO Offline OP
E
IN
Ok guys. Let's get it going here.....
If we look at the question; "The car hooks then spin, or rear tire wads really bad from too hard of a hit to the tires?
Consider that the rear suspension typically goes into extension and the foot print (of the tire) gains weight as the housing travels toward the track. The side walls become loaded and apply downward force to the foot print. If we apply too much downward force, the tire will bounce. It is like a basketball. The harder you dribble the ball, the more it will want to return to your hand. Hit the tires too hard, they hook, wad up and then when the tire becomes round again-it will want to return to it's original shape and as the sidewall un-wads, it pushes up. That pushing up condition will relieve weight from the foot print causing wheel spin. It may be slight but it only takes a little amount. (One way this event shows up is if you see a car stretch out the front suspension as it leaves, then set the front end down only to pick it up again, it did the hook/spin deal and wadded the tires too much..
Consider a potential fix is to stiffen the extension of the rear shocks. Slowing down the separation and the extent that the rear housing (with it's mass) is traveling toward the track will result in planting the tires just enough to hook the car. Also, consider we only need enough traction to hook the available torque traveling down the driveline, thru the axles and to the rims/tires.
If you have a double adjustable shock, you can also stiffen the compression to help hold the tire down, slow the rebound effect and keep the weight at the foot print from being relieved too quickly.
There are other potential fixes too. Some aren't shock related...
Anyone have seen this before? Anyone driven a car that felt like this?
Re: Shock Tech [Re: EricatAFCO] #931969
02/18/11 08:21 PM
02/18/11 08:21 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Nice to see you join the gang Eric
I have seen this plenty of times as you stated.
I put a pair of AFCO Big Guns on the back of the car.
Compression is at 3 clicks from soft
Extension is at 8 clicks from soft
Car has very minimal body seperation just slight wrinkle in tire and pulls the front wheels up nicely.
I had to tighted up the extension to achive this
Re: Shock Tech [Re: EricatAFCO] #931970
02/18/11 08:23 PM
02/18/11 08:23 PM
Q
Quicktree Offline
Quicktree  Offline
Q
can we get a sticky for this thread
Re: Shock Tech [Re: Quicktree] #931971
02/18/11 08:40 PM
02/18/11 08:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
thanks for the sticky
I would like to know the difference in shocks, how they work, what makes one better than another, how effective the different types are etc
Re: Shock Tech [Re: EricatAFCO] #931972
02/18/11 08:43 PM
02/18/11 08:43 PM
detroit area
moderncylinder Offline
detroit area
ive always been told you run compression tight and extension loose,,, when starting off would you run in the middle of your adjustments or bias it one way or the other? how about compression 1/4 way between, bias toward being hard,, and ext in the middle?? or???
Re: Shock Tech [Re: moderncylinder] #931973
02/18/11 08:50 PM
02/18/11 08:50 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
Thanks for coming aboard.
Re: Shock Tech [Re: EricatAFCO] #931974
02/18/11 08:52 PM
02/18/11 08:52 PM
oregon
greendart408 Offline
oregon
I have been having this issue for awhile now. Car initially hooks then spins bad....I have had my double adj shocks all over with the adjustments and nothing seems to work at all. Have had 3 diff rear springs on it as well 150, 130, and now currently. 110s. Made no change. I run ladder bars. Im thinking I need a stiff sidewall tire. I run a 29.5x11.5 mt. Car runs mid to upper 1.3 s and 9.60s and weighs 3100. Should be in the high 1.2s. I feel with my alky injection. Any suggestions? Thanks for your time.
Re: Shock Tech [Re: toddd] #931975
02/18/11 08:55 PM
02/18/11 08:55 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Yes Todd, this should be a good learning session as my car likes to unload the tires just as described.
Maybe I'll be buying some better rear shocks!!!
Re: Shock Tech [Re: superwrench] #931976
02/18/11 09:18 PM
02/18/11 09:18 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
My car separates real bad because my afco shocks can't take the horsepower...... Eric, weren't you gonna call me back
Re: Shock Tech [Re: joshking440] #931977
02/18/11 09:36 PM
02/18/11 09:36 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
Eric..thanks for taking the time..
hopefully you wont have to have a thick skin to make it throught the tribulation of being new to this site..
Josh..go easy on him...you may have history with him before today..
but we dont want to baptise him by fire...so give him some breathing room..
as to your direct Question as to the hopping or porposeing..i am sure your gonna get a gammot of responses..
but guys when posting a question please put a little info on your perticular suspension . stock leaf-aftermarket leaf-ladder bar leaf-caltracs or 4 link, type set ups..as its hard to discern remidies for all suspensions..when each are effected differently.
Eric.
you mention'd some factors to these issues arent all shock related..some are suspension/spring related.
some are addressed at the front of the car.
some at the rear.
we will all hit the patience button when reflecting on this thread.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Shock Tech [Re: joshking440] #931978
02/18/11 09:37 PM
02/18/11 09:37 PM
I have seen cars when they launch, the car spins and hooks and kicks left. Front end doesn't have a chance to come up.
I'm wondering if too heavy of a spring causes this.Ladder bar car with AFCO Double adjustables out back.
Re: Shock Tech [Re: cheapstreetdustr] #931979
02/18/11 09:44 PM
02/18/11 09:44 PM
Eric i dont know how intimate you are with Mopars specifically.
there are some factors that are different when diagnosing mopar type leaf sprung rear suspensions. the short front spring half is a factor. just to bring this to light not judge anyones knowledge..
i just want to put this out there..
If we are talking about mopar leaf sprung rear suspensions..
then proper rear shackle movement is a necessity to eleviate rear spring bind..in the extension of rear suspension travel..its a common problem for mopars...so is too short a shock itself..
these are both huge contributors to porpousing ..ie..hook unhook/unload..hook on a leafspring drag car..
as you can see i am passionate about this..
i am no expert...just someone who doesnt mind jumping in...ive helped fix this with a bunch of mopars...and some of it is ubiquitous in our world.
have at it..
cheapst..
and again Welcome...I am all ears..
[image][/image]
Re: Shock Tech [Re: cheapstreetdustr] #931980
02/18/11 10:08 PM
02/18/11 10:08 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
Well I have recently changed shocks from Pro-Comp truck shocks to the Rancho XL9000 series adjustable socks and have noticed a positive change.
My tires used to unload after the hit and wad up before they spun producing a very poor 1.7 60' time
Now since installing the Rancho shocks I have cut my 60' down to 1.41 on a marginal starting line.
The good shocks took the bounce out of the rear end and I am happy now and can see mid ten second ET's on the horizon
Gus
64 Plymouth Savoy
Dana 60
Re: Shock Tech [Re: cheapstreetdustr] #931981
02/18/11 10:14 PM
02/18/11 10:14 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I can see this is going to get confusing,,,it's like everybody is talking at once. Maybe,,try to answer one question at a time, and other posters have patience and just read and try to see if the questions posted are similar to their problems and learn from them...I hope Eric is ready for LOTS of PM's ...
If you like drag racing, support your local track.
Re: Shock Tech [Re: CHAPPER] #931982
02/18/11 10:39 PM
02/18/11 10:39 PM
Well his 1st post was at 5:49 pm and he hasn't been back since.
Re: Shock Tech #931983
02/18/11 11:10 PM
02/18/11 11:10 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Lets keep in mind that the guy has family and it is Friday night
Also, the thread is out here to get us some good shock technical information. The post about the basketball is the kind of thing we are looking for to get all of us thinking. That put it in terms we can all understand. We all have a car and he wont be able to tune every car on here. So lets give him a chance to give us some good information
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Shock Tech #931984
02/18/11 11:10 PM
02/18/11 11:10 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
If you saw the other thread on this, it wasnt supposed to start until Monday anyway.
Re: Shock Tech [Re: Irun5snd8th] #931985
02/18/11 11:22 PM
02/18/11 11:22 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I agree give the guy a break. I would rather hear about theory and typical scenarios anbd prinicples than how many clicks Joe blows 12 second car needs on exte sion with his SS Springs. Just saying
Re: Shock Tech [Re: Al_Alguire] #931986
02/18/11 11:30 PM
02/18/11 11:30 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Oh, just bustin his balls a little. Eric has been great to work with.... But don't tell me he doesn't deserve a typical moparts welcome
Re: Shock Tech [Re: Quicktree] #931987
02/19/11 12:15 AM
02/19/11 12:15 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
same here what is so different about the valving used by Santhuff as opposed to most other brands. What are the negatives of using them other than the outrageous costs.
home of the
Sox and Martin Hemi Duster
