Page 1 of 3 1 2 3
'08 Transmission out at 47K ??? #931788
02/18/11 03:34 PM
02/18/11 03:34 PM
Haslett, MI
7DRRunner Offline OP
Haslett, MI
I was just driving my 2008 / 3.8L around town here - in a 40 MPH zone. All of a sudden, the transmission seemed like it didn't want to shift into overdrive (at 40 mph, I was high revving at like 45000 RPMs
Then the check engine light came on (whats the trick to read the codes ?)
I pulled over and shut it off
no unusual smells, no leaks, no broken belt that I could see
Started up again. I turned afround to bring it home - first few shifts from a dead stop went OK, but when I got close to 40, it seemed to search for a gear and revved high again
I have just over 47K miles on the vehicle and its been serviced regularly ...
Since there is no dipstick to check - what's my options ?
What are your thoughts ? Transmission gone ???
"Good luck on your project." 1970 Road Runner "Accellertii Incredibus"
Re: '08 Transmission out at 47K ??? [Re: 7DRRunner] #931789
02/18/11 04:12 PM
02/18/11 04:12 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
When that happened to my '99 Dakota, it was the speed sensor on the rear axle. Easy fix in my case.
On my '04 Ram, you turn the ignition key to just before it cranks over 3 times and look at the digital odometer to view the codes.
on-off-on-off-on. Not sure if it is the same on a 2008.
Re: '08 Transmission out at 47K ??? [Re: 7DRRunner] #931790
02/18/11 04:24 PM
02/18/11 04:24 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
The Output Speed Sensor is most likely bad or covered with metal shavings. Throw a new one in and see what happens. About $25.
Re: '08 Transmission out at 47K ??? [Re: 7DRRunner] #931791
02/18/11 04:57 PM
02/18/11 04:57 PM
places
79powerwagon Offline
places
Warranty work?
Re: '08 Transmission out at 47K ??? [Re: 79powerwagon] #931792
02/18/11 05:51 PM
02/18/11 05:51 PM
Campbellsport, Wisconsin
Abodysforever Offline
Trans went into limp in mode. After you shut the car off it will drive ok untill the TCM (trans control module) sees a problem. Are you the original owner? If so it maybe warranty. Take it to a dealer so they can scan it. Ask if there are any updates (flashes) for the TCM while you are there. Those are reprogramable and the factory poss has new software so get that done. Those transmissions have most of there problems behind them so let hope it is minor. 1 tip. If its is somthing major and its not warranty. Ask for any warranty assistance, if they are no help call the chrysler 1-800 # in the back of your owners manual and ask for help. Remember to be nice, you get more bee,s with honey!
Also 80% of the time a speed sensor will turn on a check engine lamp, and poss the speedo goes out with it.
Re: '08 Transmission out at 47K ??? [Re: Abodysforever] #931793
02/18/11 06:32 PM
02/18/11 06:32 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
bring it to any national auto parts chain store and they can read the OBDII code for free.
My 96 Ram acted similar and it turned out to be the line pressure sensor. Easy fix.
Re: '08 Transmission out at 47K ??? [Re: RangerDan440] #931794
02/18/11 09:15 PM
02/18/11 09:15 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
if it shifts normally thru the fist 3 gears then acts up when it attempts to go to 4th.a speed sensor isn't going to fix it
My bet is you have internal gear train issues.
pull the pan and look for metal fragments. hopefully you got the lifetime drivetrain warrenty as I think your going to need it
Re: '08 Transmission out at 47K ??? [Re: 7DRRunner] #931795
02/19/11 12:41 AM
02/19/11 12:41 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
My guess is without knowing what the vehicle is, all other guesses are just, well, guesses.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: '08 Transmission out at 47K ??? [Re: Evil Spirit] #931796
02/21/11 01:15 PM
02/21/11 01:15 PM
Haslett, MI
Haslett, MI
Well, here's the verdict and its a bad one
On the way down to the dealership, the tranny slipped a couple of times in 3rd gear
It was whining so loud, you thought I would have been driving a Police car with the siren on ...
Dealer says 4th / 5th and 6th gears are gone and verified that it slips in third
(Service writer said they had a tranny software fix and they did that (and another recall while I was there - ) and I drove it out about 300 yards from the dealership, the check engine light came back on and it was slipping all over the place
U turn
The Service Manager said, sorry, looks like your transmission is shot .... 2nd owner so there is no warranty
Best guess to fix: around $4000 .....
So I got a rental (Caliber) and it -might- be done by Friday ....
until then I'll be at www.UnHappyCamper.com
of course, I got the story that it just depends on what all they find ... as soon as its fixed, I'll be traded it in ...
Re: '08 Transmission out at 47K ??? [Re: 7DRRunner] #931797
02/21/11 01:22 PM
02/21/11 01:22 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Even though you still haven't said what kind of car it is, I don't know of a trans that the aftermarket or private shops get 4 grand to fix. I'd call around before I'd cut them a check.
Re: '08 Transmission out at 47K ??? [Re: Evil Spirit] #931798
02/21/11 01:24 PM
02/21/11 01:24 PM
Haslett, MI
Haslett, MI
Sorry
its a 2008 Chrysler Town and Country Mini Van
Re: '08 Transmission out at 47K ??? [Re: 7DRRunner] #931799
02/21/11 02:05 PM
02/21/11 02:05 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Try here:
Link
Rich H.
Esse Quam Videri
Re: '08 Transmission out at 47K ??? [Re: ZIPPY] #931800
02/21/11 02:19 PM
02/21/11 02:19 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Try here:
Link
Yeah, Fraleys did some work for us on older stuff when I worked for a resto shop in Novi. They seemed to do a good job and priced us pretty fair.
Re: '08 Transmission out at 47K ??? [Re: Evil Spirit] #931801
02/22/11 12:43 AM
02/22/11 12:43 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
There have been quite a few problems with the new 6 speed it seems. Why is there no warranty just because you are the second owner? Can it not be transferred? Did you buy it from a dealer? I'd be screaming really load about that one, with the known issues of the 61TE tranny, they should just cover it for you. Not sure if the aftermarket is up to speed on these yet.
Re: '08 Transmission out at 47K ??? [Re: 10sec440] #931802
02/22/11 12:46 AM
02/22/11 12:46 AM
Haslett, MI
Haslett, MI
Chrysler Service Adviser says since I'm 2nd owner, all you get is a 3yr/36K mi and I'm at 47K so I'm screwd, The Limited Lifetime Powertrain Warranty is not transferrable. If you are the 2nd owner, all you get is a 3yr/36K mi. Now the 2010 and 2011 is different. They have a 5yr/100K mi Limited Powertrain Warranty. That stays with the vehicle. No transfer fee, good no matter how many owners, no fine print.....
Re: '08 Transmission out at 47K ??? [Re: 10sec440] #931803
02/22/11 12:59 AM
02/22/11 12:59 AM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
The number 5 thrust bearing fails,then takes out planetary gears on some 61te trans. I am pretty sure the original lifetime warranty can not be transfered.
Re: '08 Transmission out at 47K ??? [Re: mod381] #931804
02/22/11 02:30 AM
02/22/11 02:30 AM
Ohio
Todd Offline
Todd  Offline
Ohio
Seen A ton at the shop do the same thing. Darn near welds itself together. Sorry about your luck.
Re: '08 Transmission out at 47K ??? [Re: 7DRRunner] #931805
02/22/11 02:46 AM
02/22/11 02:46 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I think you should be loyal & trade your 08 T & C minivan in for a 2011 T & C minivan....
Re: '08 Transmission out at 47K ??? [Re: 1_WILD_RT] #931806
02/22/11 08:39 AM
02/22/11 08:39 AM
Haslett, MI
Haslett, MI
that ain't going to happen
how's that old saying go ?
Fool me once, shame on you ....
Re: '08 Transmission out at 47K ??? [Re: 7DRRunner] #931807
02/22/11 12:09 PM
02/22/11 12:09 PM
Littleton Colo
Geezer Offline
Geezer  Offline
Littleton Colo
Maybe a nice new Fiat that requires premium fuel?
Page 1 of 3 1 2 3
