FAST #170634 O2 Sensor Kit Install
#931569
02/18/11 08:45 AM
02/18/11 08:45 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
After thinking about this for over a year, I finally settled on the FAST #170634 analog A/F kit. This kit comes with the gauge (bracket not included), harness, and a single O2 sensor. I was looking for something simple and less expensive that I could mount and leave it alone for my street car. A couple of years ago when I put on the headers, I located the bungs for both sides and had them welded in. Now that I finally got around to buying the kit, the O2 sensor went right in with no interferences. I currently have it mounted on the drivers side and hopefully down the road I will buy a second one for the passenger side. So far the install is going smooth. The location for the drivers side O2 sensor worked out so that I can route the harness straight up to the floor where the 727 linkage comes thru. There is a rubber boot there around the shaft which allowed me to run the harness thru and then I added silicone to seal it up tight from water or dirt. This landed the end of the harness/O2 sensor connector just inside of the car which is located under the center console. This allowed me to mount the processor under the center console where it is hidden from view. Then I rolled up the harness under the carpet and ran it forward towards the fire wall. Now I can mount my gauge and run all of the wire up and under the dash where everything is still hidden from view. I still need to wire in the gauge but so far this kit is very simple to install. I should have the wiring buttoned up this weekend. If you are looking for a lesser optioned O2 sensor kit, check out the FAST #170634.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: FAST #170634 O2 Sensor Kit Install
[Re: YO7_A66]
#931570
02/18/11 08:47 AM
02/18/11 08:47 AM
YO7_A66
Indiana
The first picture shows that the clearance is fine to run up to two sensors with a 727. This picture shows where the sensor cable goes up thru the floor shifter linkage boot with no cutting involved.
[Re: YO7_A66]
#931572
02/18/11 08:57 AM
02/18/11 08:57 AM
YO7_A66
Indiana
This is the wiring schematic that comes with the kit. It is very clear and easy to follow.
[Re: astjp2]
#931576
02/19/11 11:35 AM
02/19/11 11:35 AM
YO7_A66
Indiana
Tim, I should be able to finish the gauge wiring next week and then once our weather decides to turn for the better, I will get the car out and start tuning with it. Thanks
