727 - Converter Stall keeps to high, why? #931555
02/18/11 06:52 AM
02/18/11 06:52 AM
Bern, Switzerland
6o4o Offline OP
6o4o  Offline OP
Bern, Switzerland
I got a weird thing going on with a freshly rebuild 727 and a new 9.5" converter behinda 500CID with a roller camshaft making some nice horsepower! Street car, no race car.
First converter flashed at around 4000RPM although we expected it to be around 3000RPM. Otherwise the 727 shifted nice. (TF2 Kit, red racing clutches etc.)
The converter maker made a new converter and said it should get 800RPM lower flash stall.
The 727 was inspected after a few 1000miles and it looked brand new! All perfect!
Test drive a while ago with new converter showed 200RPM lower flash stall than before, although 800RPM were expected!
Converter builder really can't explain it and he said it's almost the tightest converter he can build in 9.5".
Now my question: anyone of you ever experienced somethign like that? Could it be a to low converter oil pressure? Something wrong in the converter lube circuit of the Valvebody? The line pressure can't be so bad since the clutches and bands looked like new when inspected and it was driven hard! But something really is weird here...
Any ideas?
Re: 727 - Converter Stall keeps to high, why? [Re: 6o4o] #931556
02/18/11 12:46 PM
02/18/11 12:46 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
You're worrying too much?
If everything is working well as far as driveability, I'd be happy that it is what it is. Just remember don't drive around in third gear low speed "up on the stall". People street drive 8" 5000 stall units.
Re: 727 - Converter Stall keeps to high, why? [Re: RemCharger] #931557
02/18/11 01:13 PM
02/18/11 01:13 PM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
2X
500 ci,roller cam and it's not a race car? If it were mine,I put that first convertor back in! No seriously,a 500ci motor will stall higher than a smaller motor.
Re: 727 - Converter Stall keeps to high, why? [Re: jvcuda] #931558
02/18/11 01:46 PM
02/18/11 01:46 PM
Bern, Switzerland
6o4o Offline OP
6o4o  Offline OP
Bern, Switzerland
the customer doesn't want it to stall this high... the cam starts to pull at 3000RPM, so 4000RPM higher is lost RPM.
No, it's not a race car... here tons of those 500CID cars drive around (illegaly since it's illegal to have more than 20% more HP than stock!) and none of them drives races (also illegal here or almost illegal at least)
But anyway, I am wondering what could change the stall besides the converter itself? If the converter pressure spring in the valvebody could do that for example?
Re: 727 - Converter Stall keeps to high, why? [Re: 6o4o] #931559
02/18/11 01:57 PM
02/18/11 01:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't think it's a pressure thing , the stall is a function of the design of the internals of the convertor , convertor science is black magic. You might have to switch another convertor design .
Re: 727 - Converter Stall keeps to high, why? [Re: JohnRR] #931560
02/18/11 02:41 PM
02/18/11 02:41 PM
Bern, Switzerland
6o4o Offline OP
6o4o  Offline OP
Bern, Switzerland
what if the valvebody sends not enough oil to the converter like it happens in P? I would guess stall would also get higher / more slip?
By the way, it's an AUTOMATIC shift TF-2, no manual valve body...
Re: 727 - Converter Stall keeps to high, why? [Re: 6o4o] #931561
02/18/11 02:42 PM
02/18/11 02:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If it has a TF 2 it should have came wit ha new manual valve to remedy that, it's not a pressure thing , it's the convertor , where did you get it from ?
Re: 727 - Converter Stall keeps to high, why? [Re: JohnRR] #931562
02/18/11 03:12 PM
02/18/11 03:12 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Couple things; If you take off the return cooler line, it should be pushing out a good amount of fluid. Now you know the convertor is full of fuid.
Next, Why don't you just run a small(340) original convertor? Or something similar.
Re: 727 - Converter Stall keeps to high, why? [Re: RemCharger] #931563
02/18/11 07:54 PM
02/18/11 07:54 PM
Bern, Switzerland
6o4o Offline OP
6o4o  Offline OP
Bern, Switzerland
originaler convertor with 600HP? Why spend so much money on an engine to waste it on a piece of crap of converter? I installed over 60x 9.5" converters and I heck know the difference between a 11" stocker and a good 9.5"! It's day and night!
Re: 727 - Converter Stall keeps to high, why? [Re: 6o4o] #931564
02/18/11 08:09 PM
02/18/11 08:09 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Now you've hurt my feelings
Re: 727 - Converter Stall keeps to high, why? [Re: 6o4o] #931565
02/18/11 09:14 PM
02/18/11 09:14 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Sounds like a 10 or 11 inch might suit you better if you want less stall. Why are you convinced that you should have a 9.5? 3800 is pretty tight for a 9.5 behind a 500 inch motor. I dont think they could build a 9.5 with much less stall than that.
Re: 727 - Converter Stall keeps to high, why? [Re: forphorty] #931566
02/18/11 10:24 PM
02/18/11 10:24 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
a 10 in converter would be closer to your needs with that much engine torque.. heck my stock 340 converter behind a mild 383 is pretty slippery... dan
Re: 727 - Converter Stall keeps to high, why? [Re: forphorty] #931567
02/19/11 04:07 PM
02/19/11 04:07 PM
Bern, Switzerland
6o4o Offline OP
6o4o  Offline OP
Bern, Switzerland
You can build a 9.5" tighter than an 11"! I had 9.5" that stall at 2000RPM, it all depends what the converter maker makes out of it!
The 9.5" ist just the much better piece than a 11" stock converter...
But anyway, not discussing the size of the converter
So the conclusion is, the converter is the problem, not the trans/valvebody?
Re: 727 - Converter Stall keeps to high, why? [Re: 6o4o] #931568
02/19/11 04:30 PM
02/19/11 04:30 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Its the converter. I had a 9.5 behind my 470RB and a 3.55 rear and I hated the slippping ALL the time. I replaced it with a stock 11.75 converter (around 1800 stall) and it will still fry the tires off the car. If you have a monster cam or a small block you need the higher stall but most high TQ big blocks will do just fine with a stock type stall and drive way better on the street.
