Indy Horsepower !
#931477
02/18/11 02:52 AM
02/18/11 02:52 AM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
HI guys ! Putting my combo together and get a lt of comments from it, but never from people who know what they are talking about, so I'm turning to you. Here is what I have: 408 cid 360-1 heads 210cc int runner version race port 10.9:1 cr 190lbs cranking pressure HUghes engines cam 252/256* dur @ 50 626 lift Indy Intake 800 cfm Holey 904 trans, 3800 stall, low gearset 3.91 rear gear on 35 spline spool 28x9 ET drag slicks In a 67 Barracuda 3300 lbs elec water pump, manual steering
what would me my Et's ? HP ?
Trying to clear up all the [Edited by Moparts - Family Friendly Site - Keep it clean] coming to me and get reliable comments...
Dan
Re: Indy Horsepower !
[Re: Wedgeman]
#931480
02/18/11 08:49 AM
02/18/11 08:49 AM
Posts: 52,972 Romeo MI
MR_P_BODY
10.7 - 10.8... if all goes good... I'm assuming this is a track car... I'm curious why that duration... seems short for a 408(strokers like duration) and they like carb
[Re: MR_P_BODY]
#931481
02/18/11 10:05 AM
02/18/11 10:05 AM
Posts: 3,456 Out West
408strokerdart
Out West
Was thinking the same thing about both the cam and carb. Duration looks at least 10 degrees to short and it would love a 950 carb.
[Re: Wedgeman]
#931485
02/18/11 01:30 PM
02/18/11 01:30 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Guys, notice he is running only a 28" tire so he isn't too far off on gearing and converter.
When I had a home ported stock headed 408, .540 flat solid, 950hp carb, 4.56 gear, 30" tire, 4000 stall, 3500 lbs, I went 11.20 at 119.
He should be all over 10.7's.
But, with a little more gear and converter, easy mid 10's.
[Re: TheOtherDodge]
#931486
02/18/11 09:05 PM
02/18/11 09:05 PM
Wedgeman
Thanks for all your input guys. First, I wanted to choose that cam because I did not want to let too much pressure out, and stay around 185 cranking pressure
Second, remember that I run a 904 with a low gearset, wich make a 3.91:1 act like a 4.30! You think it would be wrong to keep my 28'' slicks ?
What would you change?
Dan
[Re: Wedgeman]
#931488
02/18/11 09:15 PM
02/18/11 09:15 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
I think with the right converter, trans and gear that the combo should be good for low 10s. My brothers car sounds quite similar to what you are explaning and it goes 10.50s @ 125 with a 28X9 Hoosier slick. You heads are bigger, cam seems more aggressive and the cubes are more than ours...I think you will go faster than 10.50s.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: PUNK]
#931489
02/18/11 09:43 PM
02/18/11 09:43 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
I figured between 535 and 550 HP. Should go 129 MPH+ @ 3300 lbs.
[Re: sshemi]
#931496
02/19/11 08:38 PM
02/19/11 08:38 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I think the combos pretty good except for the stall. It could be higher IMO, more like 4500 to 4800. The gearing is fine, those 9 x 28 MT ,ET tires are actually 27.3" With the 3.91, thats actually the same gearing as a 4.56 gear and 32" tire.
With that 3800 stall and 3300# Im guessing 11.0s to 11.20,s
