1971 340 'Cuda, which power steering pump is correct?? #93098
07/22/08 08:03 PM
07/22/08 08:03 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
On a 528 (May 28, '71) SPD 1971 340 'Cuda with A31 (3.91s) & S74 (quick ratio power steering) which style power steering pump is correct (Federal or Saginaw)?
& should it have a power steering cooler??
Re: 1971 340 'Cuda, which power steering pump is correc [Re: 6bblgt] #93099
07/22/08 08:11 PM
07/22/08 08:11 PM
New Jersey Bada Bing
bremotorsports Offline
Dan,
My 340 convertible (3/31/71) is a Fast Ratio S74 car, and it has the Federal pump, and 2891232 hose (stamped, with service number being 3420193). Since it has a 3.23 ratio axle, it has no cooler. More than likely, yours should. I would question a Saginaw pump being on a Fast Ratio car, cooler or not.
Bill Rolik
Re: 1971 340 'Cuda, which power steering pump is correc [Re: bremotorsports] #93100
07/22/08 08:19 PM
07/22/08 08:19 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: 1971 340 'Cuda, which power steering pump is correc [Re: Alaskan_TA] #93101
07/22/08 09:14 PM
07/22/08 09:14 PM
Yes, as luck would have it, the bulletin is at my warehouse.
The 2891218 pump is definitely a Saginaw, and the 3004799 is definitely a Federal.
The 3404435 splash shield is the standard plastic unit, and the 3583003 splash shield is the steel unit with the stapled-on seal, made of masticated rubber. The E-Body steel shields, used on Fast Ratio cars only, are actually factory modified versions of the B-Body shields from previous years, with a different seal for E-Body as well.
With regard to the hose, however, and per the bulletin, the 2891208 is NOT what was factory installed on my Fast Ratio car.
Hose combinations as follows:
Federal Fast Ratio: Service 3420193 (Stamped 2891232) Used on A-Body cars also.
Federal Standard: Service 3420194 (Stamped 2891214)
Saginaw: Service 2891208 (Stamped 2891208)
Bill Rolik
Re: 1971 340 'Cuda, which power steering pump is correc [Re: bremotorsports] #93102
07/23/08 08:31 PM
07/23/08 08:31 PM
View #2 (Hose engineering number 2891232)
BR
Re: 1971 340 'Cuda, which power steering pump is correc [Re: bremotorsports] #93103
07/23/08 08:32 PM
07/23/08 08:32 PM
View #3 (Date code)
Hope this helps!
BR
