1970 HP Big Block exhaust manifold bolts diagram ? #93085
07/22/08 07:32 PM
07/22/08 07:32 PM
N.W. Indiana
62maxxx Offline OP
62maxxx  Offline OP
N.W. Indiana
HiYa, all... does anyone have a visual diagram of where the correct places the factory exhaust manifold bolts and studs and those long barrel nuts go to? Or a very reasonable explanation? Thanks so much! MoPower to ya! My E-mail is : Magnumforce440@comcast.net
Re: 1970 HP exhaust manifold bolts diagram ? [Re: 62maxxx] #93086
07/22/08 09:54 PM
07/22/08 09:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
big block or small block ???
Re: 1970 HP exhaust manifold bolts diagram ? [Re: JohnRR] #93087
07/23/08 04:54 PM
07/23/08 04:54 PM
N.W. Indiana
62maxxx Offline OP
62maxxx  Offline OP
N.W. Indiana
Big Block
Re: 1970 HP exhaust manifold bolts diagram ? [Re: 62maxxx] #93088
07/23/08 04:59 PM
07/23/08 04:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you look at the manifolds it you should be able to match the barrel nuts to the right spots. They are inset in different depths.
Re: 1970 HP exhaust manifold bolts diagram ? [Re: stumpy] #93089
07/23/08 05:26 PM
07/23/08 05:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yep its that simple .
There are 2 different size barrel nuts , the 2 long ones on the passenger side , the one shorter one on the drivers side . All the studs are the same length ...
