Anybody run original leaf springs? #930811
02/16/11 11:45 PM
02/16/11 11:45 PM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
I'm looking at the rear end installation in my '65. The leaf springs look pretty good, the height of the car is good, and although the mount bushings are old, I don't feel any slop in the mounting points. I'm thinking I'll go with the original set up, at least for now. I've replace the 8 3/4 center section, checked and repacked the axle bearings and replaced the axle seals. Am I nuts for not removing/replacing the springs?
Re: Anybody run original leaf springs? [Re: Ramrod39] #930812
02/16/11 11:57 PM
02/16/11 11:57 PM
IN
ahy Offline
ahy  Offline
IN
If height and ride are OK and they look OK I'd say use them - preferably with new bushings. Not nuts at all.
Re: Anybody run original leaf springs? [Re: ahy] #930813
02/17/11 08:04 AM
02/17/11 08:04 AM
scratchnfotraction Offline
let them ride if they check ok on the bushings
Re: Anybody run original leaf springs? [Re: Ramrod39] #930814
02/17/11 09:37 AM
02/17/11 09:37 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
swapped an 8 3/4for a dana and used original springs...no issues
Re: Anybody run original leaf springs? [Re: ahy] #930815
02/17/11 10:02 AM
02/17/11 10:02 AM
X2. I'm assuming this is for a little stoplight action & not a dragger or other app where their function is critical.
Re: Anybody run original leaf springs? [Re: RapidRobert] #930816
02/17/11 11:57 AM
02/17/11 11:57 AM
michigan woods
imfixinmopars426 Offline
michigan woods
i drug an old set of super trac pack springs out of storage,and installed them on the charger..sets right,no lean,or stupid jacked up look of the SS springs...use them!
Re: Anybody run original leaf springs? [Re: imfixinmopars426] #930817
02/17/11 12:25 PM
02/17/11 12:25 PM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
Thanks, guys. Thats what I thought, but a little confirmation is nice.
