will a cable driven speedo work with a 518? #930759
02/16/11 11:08 PM
02/16/11 11:08 PM
Tampa FL
hemibeep Offline OP
hemibeep  Offline OP
Tampa FL
so i have a 518, in a 71 ply. can i use the old speedo pickup with the factory speedo? Seem the 518 has a smaller diameter speedo nylon gear. thanks
Re: will a cable driven speedo work with a 518? [Re: hemibeep] #930760
02/16/11 11:14 PM
02/16/11 11:14 PM
Northern Pa
GLR Offline
GLR  Offline
Northern Pa
I retro fitted a 1990 A-518 into a 72 Duster. I was able to use the speedometer cable with out a problem.
Re: will a cable driven speedo work with a 518? [Re: GLR] #930761
02/17/11 09:02 AM
02/17/11 09:02 AM
Tampa FL
hemibeep Offline OP
hemibeep  Offline OP
Tampa FL
so a basic 904/727 old style housing and larger nylon gear works?
wow, i have been overthinking this...
Re: will a cable driven speedo work with a 518? [Re: hemibeep] #930762
02/17/11 01:46 PM
02/17/11 01:46 PM
Finland
mafo Offline
mafo  Offline
Finland
If you need to use both speed sensor and cable, use sensor from a early Dakota
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
