\\\\\\ Need expert help with 727 woes //////
#930534
02/16/11 08:13 PM
02/16/11 08:13 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
To anybody that can help figure out the problem with my driver. I'm experiencing delayed/slow engagement in forward gears when the trans is shifted from P,R or N to any forward drive position. After traveling a very short distance (5-10') in the forward gears it fully engages and works fine unless the trans is shifted out of the forward gear then it starts all over again. Other than this the trans will shift excellent and operates as it should. I must add I have no history on the trans but know it does have a shift kit of some sort I installed fresh fluid and filter, band adjustment has checked out A-OK. Sorry so long, thanks for your help! Greg
Re: \\\\\\ Need expert help with 727 woes //////
[Re: Slider]
#930536
02/17/11 02:18 AM
02/17/11 02:18 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
I am no expert, but just had a thought (so don't flame me! LOL!) But...after you changed the fluid and filter, did you re-check the fluid level? Sounds like it is acting low to me.
, did this just occur or is it new since the fluid/filter change ?
[Re: roadhazard]
#930542
02/20/11 04:14 PM
02/20/11 04:14 PM
JohnRR
Bill, I checked the band adjustment, fresh fluid & filter before I installed it initally FWIW
Rear clutch problem???
Sounds like it, leakage at the seals or sealing rings.
It takes considerably more pressure to apply a clutch than it does to keep it applied.
So I assume the issue lies within the trans and not the valve body. And the only fix is to tear it down and rebuild it.
Thanks for all the responses
It's either the fluid level , VB or the rear clutch , 2 you can check without dropping the trans the other you can't , if you have access to another VB it's worth a shot to swap it out .
[Re: JohnRR]
#930543
02/20/11 08:04 PM
02/20/11 08:04 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I can loan him a VB so that's no biggie if he dosn't have one.
If it was in the rear clutch, would it show up doing an air check?
If so at least that we car do with out dropping the trans.
[Re: JohnRR]
#930546
02/22/11 01:33 PM
02/22/11 01:33 PM
roadhazard
Akron, Ohio U.S.A.
It would be a shame to drop the trans just to replace some rubber seal rings
May try some Trans-Medic
Pay me now or pay me later ... Trans medisc is a bandaid used by used car sales hacks , all it has something in itto swell the seals , eventually they will fail , and it will be alot more than the original one ...
Of course the usual suspects will chime in that they have had trans medic in their auto trans since the beginning of time with well over 5,000,000 miles ...
Thanks John!! I was really just kidding about the Trans-Medic Do it and do it right the first time and you'll never be sorry Just not looking forward to yanking the thing back out But I have a couple cores to choose from for rebuild and just make the swap in one day
