\\\\\\ Need expert help with 727 woes ////// #930534
02/16/11 08:13 PM
02/16/11 08:13 PM
Akron, Ohio U.S.A.
roadhazard Offline OP
Akron, Ohio U.S.A.
To anybody that can help figure out the problem with my driver.
I'm experiencing delayed/slow engagement in forward gears when the trans is shifted from P,R or N to any forward drive position.
After traveling a very short distance (5-10') in the forward gears it fully engages and works fine unless the trans is shifted out of the forward gear then it starts all over again.
Other than this the trans will shift excellent and operates as it should.
I must add I have no history on the trans but know it does have a shift kit of some sort I installed fresh fluid and filter, band adjustment has checked out A-OK.
Sorry so long, thanks for your help!
Greg
Re: \\\\\\ Need expert help with 727 woes ////// [Re: roadhazard] #930535
02/17/11 12:26 AM
02/17/11 12:26 AM
USA
Slider Offline
super gas
Slider  Offline
super gas
USA
I am no expert, but just had a thought (so don't flame me! LOL!) But...after you changed the fluid and filter, did you re-check the fluid level? Sounds like it is acting low to me.
Re: \\\\\\ Need expert help with 727 woes ////// [Re: Slider] #930536
02/17/11 02:18 AM
02/17/11 02:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
, did this just occur or is it new since the fluid/filter change ?
Re: \\\\\\ Need expert help with 727 woes ////// [Re: JohnRR] #930537
02/17/11 02:30 AM
02/17/11 02:30 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I talked to Greg on the phone earlier about this and the jist of what I got that it was doing it prior to the fluid/filter change.
The fluid/filter change and checking the bands were in an effort to fix the problem.
Re: \\\\\\ Need expert help with 727 woes ////// [Re: WILD BILL] #930538
02/17/11 03:07 AM
02/17/11 03:07 AM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Rear clutch problem???
Re: \\\\\\ Need expert help with 727 woes ////// [Re: superwrench] #930539
02/17/11 03:46 AM
02/17/11 03:46 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
It sounds like you have an issue with the accumulator. All it does is provide a cushion when you shift into drive. Maybe it's taking too long to overcome.
http://www.allpar.com/mopar/transmissions/torqueflite-tom-hand.html
Re: \\\\\\ Need expert help with 727 woes ////// [Re: superwrench] #930540
02/17/11 06:14 PM
02/17/11 06:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Sounds like it, leakage at the seals or sealing rings.
It takes considerably more pressure to apply a clutch than it does to keep it applied.
Re: \\\\\\ Need expert help with 727 woes ////// [Re: John_Kunkel] #930541
02/20/11 01:00 PM
02/20/11 01:00 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Bill, I checked the band adjustment, fresh fluid & filter before I installed it initally FWIW
So I assume the issue lies within the trans and not the valve body.
And the only fix is to tear it down and rebuild it.
Thanks for all the responses
Re: \\\\\\ Need expert help with 727 woes ////// [Re: roadhazard] #930542
02/20/11 04:14 PM
02/20/11 04:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's either the fluid level , VB or the rear clutch , 2 you can check without dropping the trans the other you can't , if you have access to another VB it's worth a shot to swap it out .
Re: \\\\\\ Need expert help with 727 woes ////// [Re: JohnRR] #930543
02/20/11 08:04 PM
02/20/11 08:04 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I can loan him a VB so that's no biggie if he dosn't have one.
If it was in the rear clutch, would it show up doing an air check?
If so at least that we car do with out dropping the trans.
Re: \\\\\\ Need expert help with 727 woes ////// [Re: WILD BILL] #930544
02/22/11 10:36 AM
02/22/11 10:36 AM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
It would be a shame to drop the trans just to replace some rubber seal rings
May try some Trans-Medic
Re: \\\\\\ Need expert help with 727 woes ////// [Re: roadhazard] #930545
02/22/11 11:15 AM
02/22/11 11:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Pay me now or pay me later ... Trans Medic is a bandaid used by used car sales hacks , all it has something in it to swell the seals , eventually they will fail , and it will be a lot more than the original one ...
Of course the usual suspects will chime in that they have had trans medic in their auto trans since the beginning of time with well over 5,000,000 miles ...
Re: \\\\\\ Need expert help with 727 woes ////// [Re: JohnRR] #930546
02/22/11 01:33 PM
02/22/11 01:33 PM
Akron, Ohio U.S.A.
Akron, Ohio U.S.A.
Pay me now or pay me later ... Trans medisc is a bandaid used by used car sales hacks , all it has something in itto swell the seals , eventually they will fail , and it will be alot more than the original one ...
Thanks John!!
I was really just kidding about the Trans-Medic
Do it and do it right the first time and you'll never be sorry
Just not looking forward to yanking the thing back out
But I have a couple cores to choose from for rebuild and just make the swap in one day
Re: \\\\\\ Need expert help with 727 woes ////// [Re: roadhazard] #930547
02/22/11 03:48 PM
02/22/11 03:48 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
If it's a seal getting hard, changing the fluid will help it and will show signs of repair.( key word is IF )
I've done more than a few like this with the best one still going strong after 30K miles after the service was done
