What removes 1973 original paint #930294
02/16/11 12:32 PM
02/16/11 12:32 PM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
I'm having trouble removing the factory original paint from my 73 roadrunner. The stripper I normally use won't touch it I also tried soaking it in carburetor cleaner over night and it didn't touch it. The paint is on the hood hinges and the hood latch so I don't want to media blast it because I'm sure it will destroy these parts.
Re: What removes 1973 original paint [Re: Boise Chall] #930295
02/16/11 12:45 PM
02/16/11 12:45 PM
Utah
fast360 Offline
fast360  Offline
Utah
Not to be a smart a** but try sand paper, or bead blast it. Is there a reason you want it removed? most shops will just scuff things like that with scotch bright pads and repaint. the factory paint makes a good base it prepped right.
Re: What removes 1973 original paint [Re: Boise Chall] #930296
02/16/11 01:35 PM
02/16/11 01:35 PM
USA
b54406barrel Offline
USA
Run them by your machine shop & have him throw them in the hot tank overnight. I use to use my tank for little stuff like that all the time, just make sure nothing on it is aluminum.
Re: What removes 1973 original paint [Re: Boise Chall] #930297
02/16/11 08:23 PM
02/16/11 08:23 PM
SeventySatellite Offline
Wire wheel on a bench grinder, angle grinder, or attached to a drill will remove the old paint.
Re: What removes 1973 original paint [Re: SeventySatellite] #930298
02/16/11 08:39 PM
02/16/11 08:39 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i use soda or walnuts with good results. On hood hinges and springs i use fine glass.
Re: What removes 1973 original paint [Re: Boise Chall] #930299
02/16/11 09:58 PM
02/16/11 09:58 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
FWIW, My hinges were media blasted w/o issue, primed and then painted EK2 for my project. No damage and I think they turned out pretty nice.
65 Barracuda
70 Challenger
Re: What removes 1973 original paint [Re: jrwoodjoe] #930300
02/16/11 11:08 PM
02/16/11 11:08 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
you dont have to use a super duty abrasive to blast. plastic media, ground walnut shells, or soda, as mentioned, will strip the paint, and leave the metal unharmed. get a 5 gallon bucket, and soak them in paint stripper or brake fluid, if you dont trust blasting.
Re: What removes 1973 original paint [Re: Golden-Arm] #930301
02/16/11 11:15 PM
02/16/11 11:15 PM
Rockford, IL
foz Offline
International Diplomat
foz  Offline
Rockford, IL
very simple, GLASS BEAD blast those parts!
