Early 413 Industrial Engines (Max Wedge)
#930273
02/16/11 11:07 AM
02/16/11 11:07 AM
Posts: 506 Utah, USA
1964superstock
Utah, USA
I found a bunch of large early 1960's dodge work trucks, such as dump trucks, etc, that have 413 engines (Industrial Style). What is the current value of these blocks? Are these 413 industrial blocks desirable for guys running in the stock /super stock 426 ci Max Wedge racing?
Re: Early 413 Industrial Blocks (Max Wedge)
[Re: 1964superstock]
#930281
02/16/11 10:15 PM
02/16/11 10:15 PM
Posts: 1,209 Fredericktown, PA 15333
maundmotorworks
Stealth poster
Stealth poster
I wrote an article on this exact subject that was printed in Power Wagon Advertiser a couple months ago. Some of those engines had regular 6 bolt cranks, some had the extended flange 8 bolt crank. If you remove the 8 bolt crank, you can drop a regular 6 bolt car crank in its place. There were both 361s and 413s done like that. I wrote an article on this exact subject that was printed in Power Wagon Advertiser a couple months ago. As for the ductile iron rockers, I've seen them on the marine engines, which are the same block as the IND/Truck engines. The heavy 413 blocks can often be bored .070" to standard 426W size, and that is why many nostalgia racers and Max Wedge guys always look for them...
Maund Motorworks--supplier of high performance Mopar engines--specializing in B, RB, and Hemi. www.maundmotorworks.com
[Re: maundmotorworks]
#930282
02/16/11 10:48 PM
02/16/11 10:48 PM
Posts: 793 Utah
topbrent
Utah
maundmotorworks: I wrote an article on this exact subject that was printed in Power Wagon Advertiser a couple months ago.
Do you have a link to this article or any other info?
[Re: DoubleD]
#930283
02/17/11 12:24 AM
02/17/11 12:24 AM
1964superstock
Utah, USA
I have a 426W reverse rotation boat motor it had 516 heads with adjustable rockers - AAQA block real thick walls - heavy sucker
Thank you for the information. Do you happen to have any photos of this engine, and ductile iron rocker arms??
Does anyone else happen to have photos of a 413 industrial engine or 413/426 Marine engine with adjustable ductile iron rockers??
Thanks!
#930284
02/17/11 01:44 PM
02/17/11 01:44 PM
Posts: 1,832 Fort Morgan
1OFNONE
Has been a member for quite a few years, so relax.
Fort Morgan
I have two blocks acting as legs for a storage shelf in my garage that were taken off well pumps..
So the bartender says to the horse " Gee, Why the long face?"
