will it go 9's #930000
02/15/11 11:21 PM
02/15/11 11:21 PM
usa
hot67cuda Offline OP
usa
Been a long time coming.Eng is a 493 bb comp. 12.87to1 heads are max wedge ed victors from modern cyl head they flow 366 at 600 lift. Cam is comp 6.43 lift intake dur. 265 at.50 ext dur at.50is 270 intake maifold mopar 337 with alot of port work. rocker arms are t d 1.5 ratio 1050 e85 carb.abody 3250lbs 410 gear 4000 stall converter ladder bar car
Re: will it go 9's [Re: hot67cuda] #930001
02/15/11 11:36 PM
02/15/11 11:36 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
More gear and converter and I think it's doable..
5.53 @ 125 1/8th on the launch control..more left in her!
Re: will it go 9's [Re: hot67cuda] #930002
02/15/11 11:39 PM
02/15/11 11:39 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i hope so,is it goin in a 67 cuda?
Re: will it go 9's [Re: fishy340] #930003
02/16/11 12:31 AM
02/16/11 12:31 AM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Is that 4k convertor taking into account running on E-85?
I know when I switched it really toyed with my torque. Used to run through 1/4 mile traps at 6700. Now I I go through at 6400 in the 1/8th. Atleast with the old set up....
If you are running 29 or 30" tires, did not see in your post, it should be close.
Re: will it go 9's [Re: mopartony] #930004
02/16/11 04:51 AM
02/16/11 04:51 AM
Oh
His and Her 69's Offline
Oh
I Agree that it will be close. I think you will just make it in the 9's .
David
Re: will it go 9's [Re: hot67cuda] #930005
02/16/11 09:51 AM
02/16/11 09:51 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I'd be surprised if it didn't.
