Mini Starter Bolt #92998
07/22/08 04:47 PM
07/22/08 04:47 PM
Central Vermont
DUSTERB'D Offline OP
Central Vermont
I am installing a mini starter on my small block and the upper mounting hole is bigger than the bottam one, it appears to need a special shoulkder bolt or a bushing, anybody else run into this ? thanks in advance for any input, trying to get my new stroker motor up and running !
Re: Mini Starter Bolt [Re: DUSTERB'D] #92999
07/22/08 06:19 PM
07/22/08 06:19 PM
Northwest Chicago Suburb
DaDart Offline
DaDart  Offline
They should be the same size. They should be a 7/16. The bottom is usually a stud and the nut for the stud is a fine thread while the bolt on the top is a cource thread.
This is the same for both big and small blocks. On my son's BB we had to heli coil the stud mount since it was stripped.
3 Darts and a Ram
Re: Mini Starter Bolt [Re: DaDart] #93000
07/22/08 09:59 PM
07/22/08 09:59 PM
Central Vermont
Central Vermont
The bolt size is the same it is the mounting hole in the starter that is too big , lower hole is right size for the bolt but the upper hole is bigger, looked at a new one at the NAPA store and it is the same way, looks like there should be a shoulder bolt or a bushing to fit properly.
Re: Mini Starter Bolt [Re: DUSTERB'D] #93001
07/22/08 10:30 PM
07/22/08 10:30 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Just put in on. The starters nose pilots into the bell.
Re: Mini Starter Bolt [Re: NITROUSN] #93002
07/23/08 07:48 AM
07/23/08 07:48 AM
Central Vermont
Central Vermont
Thanks for the input, went out this AM and looked again and realized this same thing, must have been working too long when I got to this point, not thinking straight or to much beer ! Thanks again
