72 B Body drum to disc conv--wider or narrower or same? #929470
02/15/11 10:44 AM
02/15/11 10:44 AM
Springfield, MO
Steve88 Offline OP
Steve88  Offline OP
Springfield, MO
I have a 72 Satellite and I am planning to do a front drum to disc brake conversion and I would like to know if going to the disc will widen the trac width of the front end? I know that some of the aftermarket brake kits widen the front and some narrow it but I can't find any info the stock disc type set ups.
Re: 72 B Body drum to disc conv--wider or narrower or same? [Re: Steve88] #929471
02/15/11 02:06 PM
02/15/11 02:06 PM
Spartanburg SC
MoparDan Offline
MoparDan  Offline
Spartanburg SC
When I converted my 72 Satellite to disk-b I got the parts from a 72 SSP- I scavenged the lower control arms (to run sway bar) upper control arms (though they are the same) and the knuckle with the caliper assembly....There was no change in track width in my case
