HP loss/gain with compression ratio #929339
02/15/11 01:32 AM
02/15/11 01:32 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
I know this topic has been posted several times. I tried a search, but couldn't come up with anything. So, what effect does changing compression ratio have on horse power?
Thanks for any help.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: HP loss/gain with compression ratio [Re: 68LAR] #929340
02/15/11 10:06 AM
02/15/11 10:06 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
of I remember correctly the number is between 35 and 45 hp per point of compression
Re: HP loss/gain with compression ratio [Re: joshking440] #929341
02/15/11 11:37 AM
02/15/11 11:37 AM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
Thanks. I was thinking along those numbers.
Re: HP loss/gain with compression ratio [Re: 68LAR] #929342
02/15/11 11:43 AM
02/15/11 11:43 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
on my combo its 11hp/11lbft per full point. theirs a calculator on wallaceracing.com for this.
Re: HP loss/gain with compression ratio [Re: 68LAR] #929343
02/15/11 11:43 AM
02/15/11 11:43 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Wouldn't that depend alot on motor size?
Re: HP loss/gain with compression ratio [Re: supercomp] #929344
02/15/11 11:47 AM
02/15/11 11:47 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i think it does. thats why you need to use the calculator.
Re: HP loss/gain with compression ratio [Re: mopar dave] #929345
02/15/11 01:25 PM
02/15/11 01:25 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Hot rod magazine claimed 4 % per point.
Re: HP loss/gain with compression ratio [Re: 68LAR] #929346
02/15/11 01:39 PM
02/15/11 01:39 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I am interested in this. I know I went from a 11.5:1 down to 9.1:1 by changing heads and thicker head gasket. I did it to run pump gas. The difference was very noticible. The cam is probably to far off for the 9.1 combination so I can't say that compression is the sole reason.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: HP loss/gain with compression ratio [Re: 68LAR] #929347
02/15/11 01:41 PM
02/15/11 01:41 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Boffin Emeritus
Re: HP loss/gain with compression ratio [Re: mopar dave] #929348
02/15/11 09:56 PM
02/15/11 09:56 PM
NC
440Jim Offline
440Jim  Offline
NC
I thought it was informative using that calculator to show the difference
changing 1 percentage point in CR starting from different levels:
Your old Compression Ratio of 13.5 and HP of 750 is now calculated
as a Compression Ratio of 12.5 and 737.20 Horsepower.
(750-737.20)/750 x 100 = 1.71 percent
Your old Compression Ratio of 12.5 and HP of 737.2 is now calculated
as a Compression Ratio of 11.5 and 722.88 Horsepower.
(737.20-722.88)/737.2 x 100 = 1.94 percent
Your old Compression Ratio of 11.5 and HP of 722.88 is now calculated
as a Compression Ratio of 10.5 and 706.71 Horsepower.
(722.88-706.71)/722.88 x 100 = 2.24 percent
Your old Compression Ratio of 10.5 and HP of 706.71 is now calculated
as a Compression Ratio of 9.5 and 688.22 Horsepower.
(706.71-688.22)/706.71 x 100 = 2.62 percent
Re: HP loss/gain with compression ratio [Re: polyspheric] #929349
02/15/11 11:07 PM
02/15/11 11:07 PM
Az
Crizila Offline
Crizila  Offline
Az
Read my article:
http://victorylibrary.com/mopar/otto.htm
People don't seem to realize just how much the HP gain drops off at higher ratios. - and as the HP curve flattens out the $ expendature curve takes over
Fastest 300
Re: HP loss/gain with compression ratio [Re: 68LAR] #929350
02/15/11 11:17 PM
02/15/11 11:17 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Dulcich did an article on this a few years ago. He had a 440 he stacked a bunch of head gaskets on. Dynoed and added a gasket. Dynoed and added another gasket, etc. You might check the Mopar Muscle magazine website and see if it's on there.
Re: HP loss/gain with compression ratio [Re: Crizila] #929351
02/15/11 11:52 PM
02/15/11 11:52 PM
NC
440Jim Offline
440Jim  Offline
NC
Read my article:
That is one nice thing about running alcohol. It supports 14-15 CR with no more fuel cost. Unlike racing gasoline that gets real expensive to support 15 CR, even the 110 that supports 12-13 is expensive in comparison to alcohol.
But like you mention, things like head gaskets to seal that extra compression go up in cost compared to a 10 CR motor.
Re: HP loss/gain with compression ratio [Re: 68LAR] #929352
02/16/11 12:23 AM
02/16/11 12:23 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
As already stated its not a solid HP gain per comp. point. Its a percentage gain over what you already have. That percentage gain looks like a pyramid.
The biggest gains are at the lower spectrum compression ratios vs the upper compression ratios. The biggest window IMO is between 9.1 - 13.1, After that, the gains for the typical bracket racer diminish immensely .
Ive seen 4%+ between 9.5 and 10.5 resulting in a .2 ET gain with around a 500 hp motor and 3200# car. Im sure I wouldnt see the same from 10.5 to 11.5. Dulch documemted this to.
Re: HP loss/gain with compression ratio [Re: 68LAR] #929353
02/16/11 01:24 AM
02/16/11 01:24 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
This is a classic case of the law of diminishing returns. As noted the greatest percentage gains are at lower compression ratios. Another thing that has to be considered especially at higher ratios is the effect that raising the compression ratio has on flame travel. High compression often requires the use of domed pistons. If the piston design results in a negative effect on flame travel than it is entirely possible that no gain or even a loss may occur. I learned this first hand back in the late '60s with a 383 with domed pistons. I milled a set of heads .060 which typically raises compression about one full point. Result; zero, zip, nada.
Re: HP loss/gain with compression ratio [Re: 5spdcuda] #929354
02/16/11 01:49 AM
02/16/11 01:49 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Yah - all benefits are based on a non-intrusive piston dome, no change in recip weight, no weird valve relief cuts, and no closing off the chamber walls to lose a few CC.
For us flathead owners, the real big gains are going from 5:1 to 6:1.
In some cases the extra pressure will allow a bit later IVC which also adds some power, but certainly not always and not a predictable amount.
Boffin Emeritus
