440 oil priming #929303
02/15/11 12:55 AM
02/15/11 12:55 AM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
Looking to prime my 440 and I want to think that the direction to spin the drill is counter clockwise for some reason. I can't seem to find clarification on that. Can someone please chime in on the priming tips, please? Thanks!
Persistance is omnipotent Durability Engineer, Chair and Couch division...
Re: 440 oil priming [Re: 4boxers4] #929304
02/15/11 12:59 AM
02/15/11 12:59 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
turn it the same direction as the rotor turns...counter clock wise...
Tony
70 AARCuda Vitamin C
Re: 440 oil priming [Re: 70AARcuda] #929305
02/15/11 02:43 AM
02/15/11 02:43 AM
upstate, New York
jvcuda Offline
jvcuda  Offline
upstate, New York
Also while spinning the oil pump turn the motor over slowly by hand to get oil up to the heads.
Re: 440 oil priming [Re: jvcuda] #929306
02/15/11 03:08 AM
02/15/11 03:08 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Yes your drill needs to be in reverse. If you have it in the forward direction you'll spin your drill all day and not build any pressure. Having a helper turn the motor over while priming is not a bad idea.
Re: 440 oil priming [Re: 4boxers4] #929307
02/15/11 06:51 AM
02/15/11 06:51 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yup you can try it both ways, it won't hurt anything, your'll know when your going the right way by the feel of the drill motor. Took some fresh pictures of my priming rods.
The one with the yellow tape is homemade from a 3/8" peice of tubing.
Re: 440 oil priming [Re: 70AARcuda] #929308
02/15/11 10:24 AM
02/15/11 10:24 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
My engines turn clockwise But yes you reverse the drill and prime counter clockwise.
Re: 440 oil priming [Re: MoparforLife] #929309
02/15/11 12:37 PM
02/15/11 12:37 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Engine turns CW but BB rotors turn CC.
Re: 440 oil priming [Re: stumpy] #929310
02/15/11 12:42 PM
02/15/11 12:42 PM
Upper Midwest
Upper Midwest
Yep -
