Re: 72 big block oil pump removal ?
[Re: dOoC]
#928793
02/14/11 06:32 PM
02/14/11 06:32 PM
RapidRobert
I'm wondering if the inter shaft has to come out 1st. If not I'd gently pry w 2 screwdrivers opposite of each other & see if you can get it started coming out. Try em & play it by ear & see how it goes and there's alot of gasket surface area so a gouge is not going to cause a leak & if you do kick up a burr smooth it down. Yes you want to be professional & not ham fisted so START EASY & see what happens
[Re: ignoble]
#928796
02/14/11 07:34 PM
02/14/11 07:34 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
maybe just 40 years of gunk between the allen key drive and the original pump female hex ?.
No that's not it , try to find a spot on the pump body you can pry against , don't try to go between the pump and the block gasket surface though, it will come out .
[Re: BTTG]
#928798
02/15/11 09:22 AM
02/15/11 09:22 AM
Posts: 1,443 Maryland
Dads426
Maryland
If the clearances in the motor are on the loose side, the oil pressure will be low with the stock relief spring. Why not try shimming the spring or replace it with the Hemi spring before you go through all the trouble of removing the pump?
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#928799
02/15/11 09:53 AM
02/15/11 09:53 AM
Posts: 843 Suffolk,VA
ireland383
Suffolk,VA
Good suggestion!
[Re: ireland383]
#928800
02/15/11 06:09 PM
02/15/11 06:09 PM
Posts: 30,457 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Good suggestion!
Roger that ... but it is probably TOOOO late ... the pump-to-block gasket is more-than-likely ripped.
B U T ...to add ...I have pulled-apart more than my share of B engines ....and I have NEVER seen a pump that was not usable in a "normal" car.
