One wire alt. sorry #928642
02/14/11 11:07 AM
02/14/11 11:07 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
I know this has been gone over many times but can someone tell me again what to do with the wires from the old voltage regulator??
Re: One wire alt. sorry [Re: fattire] #928643
02/14/11 12:56 PM
02/14/11 12:56 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
tape them up.
Re: One wire alt. sorry [Re: 05dakota] #928644
02/14/11 01:16 PM
02/14/11 01:16 PM
GA
Boosted Offline
Boosted  Offline
GA
That is what I did..... Tape them...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: One wire alt. sorry [Re: Boosted] #928645
02/14/11 02:57 PM
02/14/11 02:57 PM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
Sounds to simple Just tape up the wires that went to the regulator and then take the regulator and the wires that went to the alt. and put them on the shelf. All the guages and everything else will work and be OK ??
Re: One wire alt. sorry [Re: fattire] #928646
02/14/11 03:11 PM
02/14/11 03:11 PM
GA
Boosted Offline
Boosted  Offline
GA
yep.. I left all that stuff on my car for looks but there is nothing hooked up the the little alt except for the one wire...
2011 RAM3500
Re: One wire alt. sorry [Re: fattire] #928647
02/14/11 03:34 PM
02/14/11 03:34 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I pulled the pins out of the plug inlet on the regulator & left the harness plugged into the voltage regulator, so it appears to look original, but isn't hooked up.
Re: One wire alt. sorry [Re: fattire] #928648
02/14/11 03:46 PM
02/14/11 03:46 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Be sure that the wire from the alternator is at least a 10 or better an 8. I used 2 #8 for my one wire. No such thing as too big, but too small is a killer.
Re: One wire alt. sorry [Re: babarracuda] #928649
02/14/11 04:45 PM
02/14/11 04:45 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I use double 10 but am going to # 6 alt to trunk! # 1 trunk to starter!
Re: One wire alt. sorry [Re: Dodgem] #928650
02/15/11 10:35 AM
02/15/11 10:35 AM
Mentor,Oh.
fattire Offline OP
fattire  Offline OP
Mentor,Oh.
What about the blue wire ? I think that it is for the ignition. I have one green wire that goes from the reg. to the alt. and one blue that goes from the reg. then splits to the alt. and goes to the ignition I think. Thanks for the advice on wire size I had some work done to the alt. at a shop and he said it put out 87 amps. at 3k so I used #10 wire. I found an 140 amp. at Summit in the bargin section for $75 looked it up in the book and it was $189 so I couldn't pass it up. It is not a mini and I run a Meziere water pump so now I have to come up with some way to mount the thing.
