I shaved almost 200 lbs off the front of my 440 truck
drop the power steering and pump
droped the power brake booster
droped the a/c heater box
droped the saddle gas tank
droped the iron intake
striped most of the wire harness out from dash and under hood
i weighed every thing that came off and weighed everthing going on
droped right at 180 lbs off the nose with the 440 in the 88 short bed
I could make the even 200 lbs if they made an alum wp housing for a truck along with the wp
also droped the stock truck axle for an A-body 8 3/4
went with weld draglights with M/Ts
I will get it weighed when it goes on the road
