pulling weight off a d150 #928553
02/14/11 02:41 AM
02/14/11 02:41 AM
Midland,Tx
wyldebill Offline OP
Midland,Tx
Trying to shave some pounds from my truck. What have you guys done to get weight off these trucks?
Re: pulling weight off a d150 [Re: wyldebill] #928554
02/14/11 08:01 AM
02/14/11 08:01 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
FG parts like the hood, front bumper, and a fabricated aluminum rear bumper, no tail gate, or much else....Mine weighed 3230 with the steel hood and front bumper....
Re: pulling weight off a d150 [Re: wyldebill] #928555
02/14/11 09:01 AM
02/14/11 09:01 AM
Lehigh Acres, Florida
rickstershemi Offline
Get rid of the crash bars in the doors, modify the k-frame, remove inner fender wells, switch to manual steering box, remove heater / ac equipment.
Is it a street/strip deal or just strip? If the latter you can go a lot further
What year....????
Rickster
Re: pulling weight off a d150 [Re: rickstershemi] #928556
02/14/11 05:00 PM
02/14/11 05:00 PM
Midland,Tx
Midland,Tx
It's an 89. Mainly street legal strip. Putting alum head bb in it. Trying to get as much extra weight out as can. Anybody know weight diff from power to hand crank windows ? plan on getting rid of all the junk under dash. Remove as much stock wiring as posible
Re: pulling weight off a d150 [Re: wyldebill] #928557
02/14/11 05:48 PM
02/14/11 05:48 PM
Dragula Offline
Dragula  Offline
Cut the bed floor and replace with aluminum...
Re: pulling weight off a d150 [Re: wyldebill] #928558
02/14/11 07:26 PM
02/14/11 07:26 PM
Des Moines, IA
CoreyWilson Offline
CoreyWilson  Offline
Des Moines, IA
There's a dodge that pulls pro stock around here and has done some considerable weight reduction. Other than gutting the cab like you've mentioned, he's said he's just gradually replaced brackets and braces with aluminum, cut some bracing from the box floor and anywhere else, etc. For us, if we remove the inner fenderwells, we need to add a plate that covers as high as the spark plugs for safety so in inner fenderwells are probably worth some pounds. It's been a while since I've have any of the glass out of a truck, but he figured replacing the side windows and rear window with lexan to be worth 65lbs.
Re: pulling weight off a d150 [Re: rickstershemi] #928559
02/14/11 09:49 PM
02/14/11 09:49 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
arnt any in PU doors
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: pulling weight off a d150 [Re: W.I.N. Racing] #928560
02/14/11 11:22 PM
02/14/11 11:22 PM
scratchnfotraction Offline
I shaved almost 200 lbs off the front of my 440 truck
drop the power steering and pump
droped the power brake booster
droped the a/c heater box
droped the saddle gas tank
droped the iron intake
striped most of the wire harness out from dash and under hood
i weighed every thing that came off and weighed everthing going on
droped right at 180 lbs off the nose with the 440 in the 88 short bed
I could make the even 200 lbs if they made an alum wp housing for a truck along with the wp
also droped the stock truck axle for an A-body 8 3/4
went with weld draglights with M/Ts
I will get it weighed when it goes on the road
