Big block Camshaft ID #928542
02/14/11 01:29 AM
02/14/11 01:29 AM
Round lake, IL
ra340 Offline OP
ra340  Offline OP
Round lake, IL
I just picked up a big block cam with H288 and 1182 stamped on the end of the cam. Does anyone one know the manufacturer?
Re: Big block Camshaft ID [Re: ra340] #928543
02/14/11 01:53 AM
02/14/11 01:53 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
It's a Crane Cam,....the 1182, I have no idea, there's no other stamps like -2c or the word "blazer" after the 288...
It's one of 2 profiles Int/Exh .458/.470 lift or .480/.494 lift
Re: Big block Camshaft ID [Re: DAYCLONA] #928544
02/14/11 04:09 PM
02/14/11 04:09 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
Crane has not produced an H-288 for the Chrysler B/RB engines. There are H-288-2 grinds for the LA, however. Any other markings on the camshaft (either end)? Regards, Chase
Re: Big block Camshaft ID [Re: cknight] #928545
02/14/11 04:42 PM
02/14/11 04:42 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Which end is the dizzy drive gear on? That'll differentiate between LA and BB.
Re: Big block Camshaft ID [Re: Fury Fan] #928546
02/14/11 09:51 PM
02/14/11 09:51 PM
Round lake, IL
ra340 Offline OP
ra340  Offline OP
Round lake, IL
The distributer gear is right behind the fuel pump drive. The only markings on the cam are on the face the sprocket sits on. 288H, 1182 and large C on top of another C. The other end had some marking that was ground off. The lift on all lobes is .300 which would be .450 with stock rockers. It looks like it could be a Crane 288H Blazer cam.
Re: Big block Camshaft ID [Re: ra340] #928547
02/14/11 11:15 PM
02/14/11 11:15 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
The C on top of the other C leads me to think it's a Comp Cam. JMO
Check their site & see if there's a match
