Question for Holley Dominator gurus #928395
02/14/11 12:17 AM
02/14/11 12:17 AM
Sacramento, Ca
sanger440 Offline OP
Sacramento, Ca
I crew chief for my buddy in his 65 chevelle running superpro a couple of times a month. 3200 pounds , 496 BBC, edelrock heads, 1050 3 circuit holley dominator(done by Promax 1.5 years ago) . We run 10 inch tires (car is not tubbed). We leave on the throttle stop at 4100 rpm, come off the throttle stop after 1.5 seconds and run 10.90 et's. We leave easy on the throttle stop to control tire spin with small tires. Car runs very consisitent and has finished top 5 the last 2 years in super pro.
But the car will cut out first pass of the day almost each race. If we put new plugs (or clean plugs) in it does not cut out. In an effort to figure out [Edited by Moparts - Family Friendly Site - Keep it clean] is going on I put a Wide Band O2 sensor and datalogged the runs today.
A/F ratio averaged 12.7-12.8 after the 60 foot mark when the car was off the throttle stop. So the car runs good when at full throttle off the TS.
But in the water box doing the burnout, the A/F averaged 10.2-10.3, staged on the throttle stop at 4100 rpm, A/F was about 11.2-11.4. The A/F for the first 60 feet or so (still on the TS) stayed about 11.5.
So I figure the car is cutting out first pass of the day because it is too rich and the motor does not have much heat in it. Once the car has one pass and is cleaned out, it no longer cuts out.
So here is the question: What can be changed on the 3 circuit dommy to lean it out for the burn out, staging on the throttle stop, and running on the throttle stop for the first 1.5 seconds.?
Re: Question for Holley Dominator gurus [Re: sanger440] #928396
02/14/11 12:41 AM
02/14/11 12:41 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
What heat range of plug?
Re: Question for Holley Dominator gurus [Re: RemCharger] #928397
02/14/11 02:45 AM
02/14/11 02:45 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I had to lean out the intermedate air bleeds on mine(made it larger)to keep it from being snotty at lower rpms.The interm. air are the ones in th middle.Most people will say go about .005 at a time. I think I ended up going at least .030.My carb was an 8896-1.
Re: Question for Holley Dominator gurus [Re: sanger440] #928398
02/14/11 02:56 AM
02/14/11 02:56 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
If it is only having an issue when cold, first pass then is fine the rest of the day why do you think it is a carb issue? Maybe the car needs ot be warmed up more beofre the first run of the day?
Having said that I would do as suggested and play with the idle and intermediate bleeds. It is pretty common knowledge that dominators are pig fat at idle and most are on the intrermediates as well. Being on the stop is not gonna help any. I would look hard at go up on the bleeds a bit on both. If you are going to leave on the stop you need to make it happier down low, IMO. We played with mine a bit to get it happy on the stop. I am on it for a good amount of time and took some tweaking to get it happy there.
Then again if it is only happeneing on the first "cold" pass maybe it just is not getting warmed up enough. Just my Having said all that Warren does pretty good as a racer so it cant be that bad
Re: Question for Holley Dominator gurus [Re: Al_Alguire] #928399
02/14/11 12:18 PM
02/14/11 12:18 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
Engine temp affects A/f ratio More than you might think , i had a mid range that was 11.5 @180 deg , put in a 195 temp t-stat .
checked again warmed up at 195deg A/f went to 12.4
1969 Dodge Charger 1969 Dodge Superbee
Re: Question for Holley Dominator gurus [Re: cjs69mope] #928400
02/14/11 01:29 PM
02/14/11 01:29 PM
Sacramento, Ca
Sacramento, Ca
Thanks guys.
We do warm the car up as much as possibe before the first pass. Put it up on jack stands and run it through the gears and get it everything up to temp. And the car is always at least 180 degrees before making a pass. Still cuts out unless we change the plugs.
I am thinking that if I can get the car a little leaner during the burnout and for the first 60 feet on the stop, maybe the car will be a little more consistent. Right now the data from the first run tends to be pretty useless because the car is so loaded up.
So which air bleeds should I change? Low, mid, or both?
Re: Question for Holley Dominator gurus [Re: sanger440] #928401
02/14/11 01:49 PM
02/14/11 01:49 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I'm no expert by any means but you have a wide band so warm it up and see what the A/F is at idle. That will let you know if that needs adjustment. I'd set this first.
Then adjust the intermediate circuit until the A/F is in line and or the motor runs like it should.
JMO
Re: Question for Holley Dominator gurus [Re: roadhazard] #928402
02/14/11 02:58 PM
02/14/11 02:58 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
If the car won't run when it's cool, you need to fix the carb. Your numbers show that it is rich at low speed, so work on this.............but......180 degrees is NOT cool, so I would check a couple other things. If it stumbles, unless you put fresh plugs in, thats an ignition issue. You might try a range hotter plug, to help clean the plug better. I never saw ignition system posted, but you may need to close the gap up on the plugs, to make it easier to light the charge........but you still need to clean the carb up at low speed.
Monte
Re: Question for Holley Dominator gurus [Re: Monte_Smith] #928403
02/14/11 03:46 PM
02/14/11 03:46 PM
UK
602heavy Offline
602heavy  Offline
UK
Remove intermediate air bleeds & go try it , my guess is it will run fine , once you establish the intermediate being the problem either block the circuit off or fine tune.
Re: Question for Holley Dominator gurus [Re: Monte_Smith] #928404
02/14/11 09:11 PM
02/14/11 09:11 PM
Wisconsin
MagnumExpress Offline
Wisconsin
Monte
I agree completly. Had this same issue. Changed plugs to one heat range hotter and problem solved
#9 in the world. 2006 IHRA Super Rod
2010 IHRA Div.5 Hot Rod Champion
Re: Question for Holley Dominator gurus [Re: Monte_Smith] #928405
02/14/11 11:46 PM
02/14/11 11:46 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Agree with what has been posted already. What plugs do you run now? As stated Dominators are notoriously fat on the idle circuit. Easy to fix with a bleed change. Gonna assume the throttle blades are not open to far allowing for to much transgfer slot to be exposed, cuase that will make it pig fat.
Re: Question for Holley Dominator gurus [Re: Al_Alguire] #928406
02/15/11 01:46 AM
02/15/11 01:46 AM
Sacramento, Ca
Sacramento, Ca
I will have to check exacty what plugs we run, autolite brand but not not sure what heat range. Something off the shelf at Kragen probably.
The ignintion is a MSD6a, we have tried the back up box and a switched to a new coil last season, car still cuts out first pass. I have ohmed the MSD plug wires, they were within spec, and new cap and rotor have been installed. We run a high output alternator, and have verified the MSD sees 14 volts when the car is running. Distributor is locked out at 35 degrees and still never kicks back. So I am thinking it is not the ignition.
The car starts excellent hot or cold, it idles good, never stumbles or surges when staging or idling around the pits. Never kicks back when starting, never seems to flood or act like it is too loaded up. But it will cut out in the water box first burnout of the day.
So I should try a bigger mid speed air bleed? (I always get this backwards)
It was suggested to remove the air bleed all together? (I don't think he meant to plug it)?
Thanks again for all the suggestions.
Re: Question for Holley Dominator gurus [Re: sanger440] #928407
02/15/11 02:19 AM
02/15/11 02:19 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The higher the bleed size/number the leaner the given circuit will be.
Re: Question for Holley Dominator gurus [Re: Al_Alguire] #928408
02/15/11 11:48 AM
02/15/11 11:48 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
My 02 is always richer in burnout. I believe its from the acc. pump when I hit it to get em spinning, or if you feather it while spinning, the nozzles are squirting right?
Possibly smaller squirters and hotter plugs.
Don
Re: Question for Holley Dominator gurus [Re: cudadon] #928409
02/15/11 02:38 PM
02/15/11 02:38 PM
Sacramento, Ca
Sacramento, Ca
Don
Excellent point Don. I have the data logger set to start logging at 3500 rpm, so it starts when the car is in the burnout. The A/F is in the 10.1-10.3 range while the car is the water box. So the Carb is at part throttle (squirters do work) and is being feathered to keep the rpm about 6000 rpm or so. Once the car is staged, on the trans brake, throttle blades are wide open (so accel pumps are done), and the throttle stop (plate type under the carb) is holding the rpm at about 4100 on the T-brake. The A/F is a little leaner here, but still very rich. So I am hoping the mid speed bleed with help here and down track until TS opens up.
What is your A/F ratio when you are doing your burnout Don?
Charlie.
Re: Question for Holley Dominator gurus [Re: sanger440] #928410
02/15/11 07:39 PM
02/15/11 07:39 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
While dataloging, What does the wideband graph show when engine "Cuts out"?
Re: Question for Holley Dominator gurus [Re: sanger440] #928411
02/16/11 12:16 PM
02/16/11 12:16 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Don
Charlie.
Charlie
My AFR with LM2 in the burnout is 10.3 avg.
It's about the same as yours.
I have seen in the past when I needed to richen the down track run, the burnout was plenty rich!
This why I think it's the acc. pump richening the burnout, I know I use the pedal to keep rpm where I want it.
I use a 2 step so I don't pay attention to AFR on the tbrake, the miss will lie to me.
I don't have a miss or anything when I let go of the button. Don
Re: Question for Holley Dominator gurus [Re: sanger440] #928412
02/16/11 04:03 PM
02/16/11 04:03 PM
Cab_Burge Online work
Cab_Burge  Online Work
turn the idle mixture screws in on all four corners to 1/4 to 1/2 turn out from all the way in and look at your AFR I have had to do that on several Dominators and other carbs. to get them to idle clean and drive clean at low RPM As already said a hotter plug and bigger idle and intermediate bleeds will help also, change one thing at at time until the motor is happy sometimes you have to change the main jest also
Re: Question for Holley Dominator gurus [Re: Cab_Burge] #928413
09/09/11 09:34 PM
09/09/11 09:34 PM
Sacramento, Ca
Sacramento, Ca
Well I thought I would reply back now that I know the car is definitely cured of it's morning cut out ritual. What we did was put a power valve in the thing and went down 10 jet sizes. Car never cut out again. We used the same plugs the rest of the year. 02 meter shows about 11.5 AFR in the burnout and when on the TS. Then the rest of the run AFR holds about 12.5 AFR.
My buddy ended up winning a Wally in super street at the NHRA Pacific Open in May at Sac raceway. Finally got his car in National Dragster LOL!. He ran back to back 10.900 in the semi and final.
It is nice to finally have the car run good all the time.
Charlie
Re: Question for Holley Dominator gurus [Re: sanger440] #928414
09/10/11 11:26 AM
09/10/11 11:26 AM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i am logging my duster also for afr. every first pass on my duster is a throw away pass cleaning the plugs.
it is real rich around 11.5 to 1 at my foot brake staging of around 2000rpms. when i pin it it takes it .7 to .8sec to go from 13.0 all the way to 10.8 then back up to 13.0 to 1 and i am blameing that on the accelerator pumps dumping. the intermeadit circuit has to be out of the picture when the throttle blades go past the notch to wide open. i got white pump cams for next time out to try and fix that. hell that is more than half of my 60ft that it is pig ritch at the spot it needs to be crisp to launch the car.
