k- member
#928352
02/13/11 11:38 PM
02/13/11 11:38 PM
Posts: 905 SD
zrxkawboy
SD
Can someone tell me where the part number is stamped on the k-member? Thanks!!
It's Swifty! Swifty, you toad sucker!
Re: k- member
[Re: screamindriver]
#928354
02/14/11 12:38 AM
02/14/11 12:38 AM
Posts: 905 SD
zrxkawboy
SD
I picked up a used k-member, and wanted to verify what it was from. It is probably pre-'70, so no number, I guess. Thank you for the helpful link!
Re: k- member
#928356
02/14/11 09:48 AM
02/14/11 09:48 AM
Posts: 905 SD
zrxkawboy
SD
I found numbers on this one: 2548 2. So, apparently it is from a '69 model, and should work fine in my '67 Belvedere. Thanks again for the help!
