Quarter Window Removal ,... 68 Barracuda Coupe #927976
02/13/11 05:33 PM
02/13/11 05:33 PM
Russ H. Offline OP
Russ H.  Offline OP
Is there a special tool used to remove the spring nuts that hold regulator arms to the glass frame? If not, what is the trick in getting those things off?
Russ
Re: Quarter Window Removal ,... 68 Barracuda Coupe [Re: Russ H.] #927977
02/14/11 09:18 AM
02/14/11 09:18 AM
Russ H. Offline OP
Russ H.  Offline OP
Anyone ??
Re: Quarter Window Removal ,... 68 Barracuda Coupe [Re: Russ H.] #927978
02/19/11 01:58 AM
02/19/11 01:58 AM
Russ H. Offline OP
Russ H.  Offline OP
Does anyone have an idea how to remove the spring washers holding the regulator to the window frames?
