69 440 HP2 BUILD DATE 1-17-69 A-12 ? #927818
02/13/11 02:04 PM
02/13/11 02:04 PM
challenger2008 Offline OP
Parts Problem
Parts Problem
IS THIS 440 BUILD DATE CLOSE ENOUGH TO USE IN A A-12 CAR ? IT NEEDS REBUILT,I HAVE THE HEADS AND 69 HP VALVE COVERS,WHAT IS IT WORTH ?
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: challenger2008] #927819
02/13/11 02:19 PM
02/13/11 02:19 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
whats the vin number on the side of it?
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: flypaper] #927820
02/13/11 02:26 PM
02/13/11 02:26 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
The 1-17 casting date is in the possible range for an A12 car. The only way to determine if it originally came out of an A12 car is to match the VIN# on the block to a known car.
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: Dave Watt] #927821
02/13/11 02:30 PM
02/13/11 02:30 PM
Parts Problem
Parts Problem
VIN # IS 9A223499,IM NOT SAYING ITS A A-12 MOTOR JUST ASKING IF IT CAN BE USED AS A REPLACEMENT AND HOW MUCH IS IT WORTH NEEDING A REBUILD
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: challenger2008] #927822
02/13/11 02:42 PM
02/13/11 02:42 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
It depends on your philosophy regarding replacement motors. Sure, any 440 can be used as a replacement motor once the original is gone because, according to some, once the original is gone it doesn't matter what goes back in the car. Non original is still non original regardless of the date on the block.
The VIN is from a car built in early February so if you are the type of person that has to have a date coded motor from exactly the range of A12 cars, then no. The VIN makes this one too early for even the first A12 cars let alone the ones built in July.
If you want to rationalize the block casting date and pretend the block was set aside for another 8 weeks to five months before it COULD have gone into an A12 car, then sure....this one would be fine.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: 69CoronetRT] #927823
02/13/11 02:54 PM
02/13/11 02:54 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
whats the assembly date might help and that can be found on the pad that says HP440
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: 69CoronetRT] #927824
02/13/11 03:20 PM
02/13/11 03:20 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
The earliest "real" A12 blocks I have seen were cast in mid Feb 1969
My block is not an HP2
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: challenger2008] #927825
02/13/11 07:32 PM
02/13/11 07:32 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I believe it has the thick horizontal rib above the freeze plugs. If so, it would be an acceptable replacement block for an A12. First, because it's the correct configuration. It's also an E440 HP. For a restoration with a non-numbers matching block, you want all other date codes that preceed the scheduled production date but the earlier 69 blocks don't have the stiffener rib on the side of the block. IMO, if it's not the original block with the matching VIN, then having a closer date coded block to the SPD does not make it better than any other block with the correct year and configuration as long as it is not a latter date code than the SPD. In the case of an A12, I would say no later than the latest other date code on the car...which may be the K frame date code. That's just one opinion. I'm sure there will be others!
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: challenger2008] #927826
02/13/11 07:36 PM
02/13/11 07:36 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Heck with the engine, lets see the A12!
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: RoadRunnerJD] #927827
02/13/11 08:19 PM
02/13/11 08:19 PM
Warrenton, VA
Warrenton, VA
It's worth as much as any other 69 HP block in the same condition, no more.
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: RoadRunnerJD] #927828
02/14/11 12:20 AM
02/14/11 12:20 AM
Illinois
V
v10 Offline
v10  Offline
V
Illinois
What is the usual dates for blocks on these cars?
Also what is the difference in a hp block and non-hp block?
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: v10] #927829
02/14/11 01:26 AM
02/14/11 01:26 AM
Warrenton, VA
Warrenton, VA
The HP was rated at 375hp and a non HP at 350hp. The blocks are the same. I think the main difference was just the cam, carb and exhaust manifolds. The A12 motor had a few special tweaks but basically the same as a regular 440 hp.
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: v10] #927830
02/14/11 01:58 AM
02/14/11 01:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
2 stamps , H and P
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: JohnRR] #927831
02/14/11 02:13 AM
02/14/11 02:13 AM
Illinois
V
v10 Offline
v10  Offline
V
Illinois
Thanks for the answers on the hp thing. I was thinking there was no difference but didn't know for sure.
Does anyone know what the usual dates for a block for a 426 dated car would be?
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: JohnRR] #927832
02/14/11 09:27 AM
02/14/11 09:27 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
2 stamps , H and P
Let me expand on what John is saying.
All 1969 440 blocks were the same . If the block was assembled with High Performance parts inside, it got the HP stamping. If it was assembled with standard performance parts, no stamping was on it.
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: v10] #927833
02/14/11 09:35 AM
02/14/11 09:35 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
There are no usual dates for a 4/26 car since they were made with that date all the way to mid July, you date the car by the parts dates on the car and by a corresponding non A12 LR car with a VIN close to your car. You can only approximate the real build date of the car and extrapolate the motor dates.
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: Dave Watt] #927834
02/14/11 11:21 AM
02/14/11 11:21 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
2 stamps , H and P
All 440 blocks were the same . If the block was assembled with High Performance parts inside, it got the HP stamping. If it was assembled with standard performance parts, no stamping was on it.
But he only asked about the block
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: JohnRR] #927835
02/14/11 11:37 AM
02/14/11 11:37 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
I know, just trying explain a little better.
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: Dave Watt] #927836
02/14/11 12:50 PM
02/14/11 12:50 PM
Illinois
V
v10 Offline
v10  Offline
V
Illinois
Thanks, I do appreciate the answers and info.
Re: 69 440 HP2 BUILD DATE 1-17-69 A-12 ? [Re: challenger2008] #927837
02/14/11 01:22 PM
02/14/11 01:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Dumb question , what is the VIN on it ? is it from a car built at lynch rd ?
