Re: Help picking a cam
[Re: Von]
#927479
02/14/11 12:36 AM
02/14/11 12:36 AM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Please define better....and why more lift is needed with stock castings?
Ive already discussed the same subject with Dwayne...
True, it will run real nice with a stock cam.
[Re: RemCharger]
#927480
02/14/11 12:38 AM
02/14/11 12:38 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
with a stock cam.
Ya, how do stockers run so well with sub 500 lift.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: HYPER8oSoNic]
#927482
02/14/11 12:41 AM
02/14/11 12:41 AM
Von
NE Oklahoma
Relax man!
[Re: Von]
#927483
02/14/11 12:52 AM
02/14/11 12:52 AM
RemCharger
Sk. Canada
with a stock cam.
Sorry, I didn't realize the OP is building a Stock/SuperStock car. Must be reading to fast.
[Re: RemCharger]
#927485
02/14/11 01:12 AM
02/14/11 01:12 AM
Von
NE Oklahoma
[Re: Von]
#927487
02/14/11 01:31 AM
02/14/11 01:31 AM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
You got me ROTFLMAO... http://www.moparts.org/Tech/Archive/bb/Lobe.htmlDang RB and MP old technology....Sure wish they would have tested some of the newer shiznit grinds. Oh wait...they did... Here, I'm throwing it back at ya!! The update (test page), works WELL for 3500-3600 pound B-bodies. The poster has nearly TWO-TONS of car. The performance of those cams DO NOT relate to his CAR WEIGHT!! Look, I'm not knocking the newer cams, but you fail to realize that WEIGHT effects the perfomance. You can make horsepower, but torque is needed to move the MASS effectively. Want to run HARDER, lighten the car!! THEN, pack in the horsepower. BTW, the RACER BROWN cam looked pretty good, probably the most driveable one of the bunch!
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
[Re: HYPER8oSoNic]
#927490
02/14/11 01:56 AM
02/14/11 01:56 AM
Von
NE Oklahoma
How do the cams NOT relate to car weight??? Look at the torque #s the RB cam put up.
I think you are not seeing my problem with some of the comments on this thread,and most other cam threads. To make the statement that "this cam, or that cam sucks, is out dated, is a SHi445 pos, etc", is totally ridicoulous.
As you said its all in the combination......I agree that most cam related problems are due to other issues, (compression, converter, advance curve, tuning, etc)
But, as in forphorty's case (whose car is no lighweight, 3600 and change I believe) if I asked 100 people what his car runs with no compression, 3.23s, very little headwork, and a high mileage motor to boot, most generally the answer would be "That cam is too big, it will be a flippin hound" or something along those lines.
Too many blanket statements thrown out on this board that are at best half true.
[Re: Von]
#927491
02/14/11 01:57 AM
02/14/11 01:57 AM
RemCharger
Sk. Canada
with a stock cam.
Peace Out!!!
Could you at least post the whole article? I didn't see the part about the sub 500 lift cams.
Andy is a serious asset to the mopar community, I'm honoured to see he recommends the same hydraulic as I do
Glad we can finally agree and move forward.
[Re: RemCharger]
#927492
02/14/11 02:05 AM
02/14/11 02:05 AM
Von
NE Oklahoma
You hittin a crack pipe? Where did I say they tested sub 500 lift cams....
Not so fast there, pundit. Looks like the old school crap RB cam took the honors.... Something to the lines that they could tell the shiznit Comp hyd didnt have the low end that the RB cam had and the dyno backed it up. Hmm, split duration had less torque than the POS old school RB, where have I heard that before?
[Re: Von]
#927493
02/14/11 02:25 AM
02/14/11 02:25 AM
RemCharger
Sk. Canada
BTW, which cam company is high lighted in the sources box??
I'm not going to dwell into Andys article as he would tell you ,which I'm sure you know, every combination is different. I said I like the XE284 over the old comp 292/501. You got agitated. Too bad we couldn't have a dyno shootout in that motor and see.Probably wouldn't end up being that far from each other.
[Re: RemCharger]
#927494
02/14/11 02:28 AM
02/14/11 02:28 AM
Von
NE Oklahoma
[quoteI said I like the XE284 over the old comp 292/501. You got agitated. Actually said that the 292 was a shi%%^ old cam. But,no harm no foul. Too bad we couldn't have a dyno shootout in that motor and see.Probably wouldn't end up being that far from each other.
Now back on track, so to speak...
[Re: Von]
#927495
02/14/11 02:33 AM
02/14/11 02:33 AM
RemCharger
Sk. Canada
[Re: Verga]
#927498
02/15/11 02:13 PM
02/15/11 02:13 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
10:1, 2" headers, 4000 stall and 4.10s.
Yep, put a .557 MP cam in it and let it eat.
Rich H.
Esse Quam Videri
