throttle linkage problem on 340 manifold #927419
02/13/11 12:18 AM
02/13/11 12:18 AM
Pittsburgh, PA
bigdaddywiz Offline OP
Pittsburgh, PA
me again guys...
in my ongoing "340 intake 4bbl onto a 318" project, i found that the throttle linkage that came off my 318 does not fit on the 340 manifold. the bolt holes line up, but it doesnt lay flush with them because the 340 intake is taller than the 318.
so my question is do i need to find throttle linkage off a 340 or does someone make a bracket that will allow for the one i have to fit on the 340 manifold?
thanks!
73 Road Runner 09 Challenger R/T
Re: throttle linkage problem on 340 manifold [Re: bigdaddywiz] #927420
02/13/11 12:37 AM
02/13/11 12:37 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Our 73 340 Challenger came with a 383 when we got it so figuring out the linkage was a pain when we put a 340 back into it. Took this pic of an original car to see what was needed. B/E bodies should be similar. This is for the one-piece kickdown. Hope this helps.
Re: throttle linkage problem on 340 manifold [Re: bigdaddywiz] #927421
02/13/11 12:50 AM
02/13/11 12:50 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
The throttle cable for a 4 barrel carb is longer than the 318 2 barrel cable. You can probably use a /6 throttle cable, they were longer than the 2 barrel cable also.
If you have an automatic with the kickdown rod with the threaded end, it will also need to be longer for the 4 barrel carb. SUmmit racing sells the Edelbrock adapters to lengthen the kickdown rod (2 different diameters, IIRC).
Four barrel throttle cable brackets, OEM and aftermarket show up on Ebag.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: throttle linkage problem on 340 manifold [Re: bigdaddywiz] #927422
02/13/11 12:54 AM
02/13/11 12:54 AM
AndyF Offline
AndyF  Offline
Mancini Racing should have everything you need. They have a full assortment of reproduction brackets as well as aftermarket throttle brackets.
Re: throttle linkage problem on 340 manifold [Re: bigdaddywiz] #927423
02/13/11 12:56 AM
02/13/11 12:56 AM
Alberta
rustbuckett68 Offline
Alberta
2 bbl. and 4 bbl. throttle brackets were different as the 4 bbl. manifold looked to have larger and higher ports. 360 4 bbl. stuff is similar, used on trucks and vans. If its a resto, well...... The 4 bbl.cable attaches at a different location because of the throttle shaft oriented in a different spot as compared to the 2 bbl.
Re: throttle linkage problem on 340 manifold [Re: rustbuckett68] #927424
02/13/11 11:15 AM
02/13/11 11:15 AM
scratchnfotraction Offline
what does the car need??
a 1 piece kick down or the 3 piece kickdown??
brackets and rods are differant right there
i have tweekd 2-v linkage to work a 4-v intake carb swap
just have to use some of the right pieces
most time the rod/blade from bell crank to throttle stud needs lengthend about 1 1/4 inch to fit with a slight bend of the bracket
/6 thottle cable will help also
I have a drawer full of brackets if you need one PM me
