bolt the crossmember up & cutout a scallop w your whizzer on the one side to match the frame so you'll have a scallop on both sides then remove it & weld on horizontle pieces to box it & restore its strength. None ever avail OE as no dual ex was offered. Search the A body "parts for sale" section here (or place a "wanted" ad) for a 65-66 A body speedo cable and there's a parts house one avail (cant remem the #) but it is longer than the stock one. EDIT any A body float will fit as will any A body tank (use the single OE transverse strap). All A tanks have the checkerboard pattern on bottom so can use any of em.
