MSD ignition question #926579
02/11/11 07:06 PM
02/11/11 07:06 PM
desomod Offline OP
desomod  Offline OP
I am looking at updating the ignition. 528" Hemi, auto trans, 3.23:1 rear end, TTI 2 1/8 into 3" exhaust. The Mopar chrome box is what I am running now but have heard alot of potential problems with them.
I am thinking the MSD 6al.
My main question is will it "plug and play" with my factory distributor or should I just replace it as well?
Re: MSD ignition question [Re: desomod] #926580
02/11/11 07:11 PM
02/11/11 07:11 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
it will work.
Re: MSD ignition question [Re: 05dakota] #926581
02/11/11 08:46 PM
02/11/11 08:46 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
it will work.
yes it will work but it will not PLUG directly in , the connectors between the 2 are different .
Are you having a problem with it now ?
Re: MSD ignition question [Re: desomod] #926582
02/11/11 11:29 PM
02/11/11 11:29 PM
If you're good now but want more I'd consider getting each subsystem of the dist spot on in order initial/total/springs/vac adv then for more going w a hotter coil and definitely peruse the coil/ballast thread on this page today
Re: MSD ignition question [Re: desomod] #926583
02/11/11 11:51 PM
02/11/11 11:51 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
MSD used to make boxes with the Chrysler plug. I bought a brand new in the box M6 off e-bagger for $140, and plugged it in. Works fine..
Just my $0.02..
Re: MSD ignition question [Re: Sinitro] #926584
02/12/11 12:08 AM
02/12/11 12:08 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
