Page 3 of 3 1 2 3
Re: 383 Quench Question [Re: HYPER8oSoNic] #926027
02/13/11 08:57 PM
02/13/11 08:57 PM
USA
JoesMopar Offline OP
USA
Ok, how about the KB 400's, zero deck the block, 84cc Edelbrock heads (don't want to machine them incase I want to use them on a 440 later on), and a .040ish head gasket.....what CR are we talking about? Does this sound good?
Re: 383 Quench Question [Re: JoesMopar] #926028
02/13/11 09:18 PM
02/13/11 09:18 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I come up with 9.890:1. I used the .040 KB400's on my build to achieve the 9.9:1. Use this calculator. http://www.kb-silvolite.com/calc.php?action=comp
Re: 383 Quench Question [Re: JoesMopar] #926029
02/13/11 09:54 PM
02/13/11 09:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No need to zero deck the block just a cut to make it SQUARE to the crank centerline is all you need to do.
Re: 383 Quench Question [Re: JohnRR] #926030
02/13/11 10:10 PM
02/13/11 10:10 PM
USA
USA
Any idea what that combo would put the CR at?
Re: 383 Quench Question [Re: JoesMopar] #926031
02/13/11 10:11 PM
02/13/11 10:11 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Can anyone tell me the best way to get quench from a 383 using the 906 heads? I looked at the Edelbrock closed chamber heads on Summit and I don't know if it was a misprint or what but it listed the bare 84cc heads for $900+ each. I think I want to use the 906 heads anyway, and if I don't like them I can always change things later on.
I'm not building a racing engine, just a nice street engine. I'm shooting for 375-400HP.
If it helps my other list of parts will be a Performer RPM, 750 carb (not sure which), XE 274 cam and matching springs, stock rockers, MP ignition, Dougs headers, and 2 1/2" exhaust. Not sure on the pistons, that depends on what you guys recommend for the 906's. The car also has a 727/3.23 SG set up.
To the original question..
My thoughts, to get quench with a 906 and a .039 gasket , the piston would need a quench pad of around.120 height above deck.
On my street 383 I used .060 milled 516s with .080 in the hole pistons. It will not run on reg gas and makes somewhere around 425 hp. Its cheap and ez, works well. With my cam choice and 3.23s it needs to see 25-30mph before it turns on.
Re: 383 Quench Question [Re: JoesMopar] #926032
02/14/11 12:38 AM
02/14/11 12:38 AM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
That's the best thing to do, I used the KB 162's and cut my heads down to 70cc to get compression. It runs pretty good but was pretty costly for what it is. The KB 400's weren't out when I built it though.
Re: 383 Quench Question [Re: 71383beep] #926033
02/14/11 06:02 PM
02/14/11 06:02 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
You could just go find some closed chamber 516 or the even better 915 head if you're looking to keep your project cheap.
Fixed. Just in case anyone comes researching thru this thread at a later date...
Re: 383 Quench Question [Re: Fury Fan] #926034
02/14/11 08:24 PM
02/14/11 08:24 PM
IL
71383beep Offline
71383beep  Offline
IL
Well i'll be humdinger...whoops! my bad. I am glad you caught that!
I fixed my post too, but yes kb 162's some meat off of the block, and worked 516's with a decent cam will get you 400 hp which is what the OP is after. I also receomend a full point more if going to edelbrock in which case different pistons are the better route.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: 383 Quench Question [Re: 71383beep] #926035
02/14/11 09:57 PM
02/14/11 09:57 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
But as JohnRR mentioned earlier in this thread the KB162's are the ones to avoid, the KB400's are a better choice, still not ideal but much better than the 162's.. It would be nice if one of the piston manufacturers stepped up & gave us a real good choice, currently none exist...
Re: 383 Quench Question [Re: 1_WILD_RT] #926036
02/14/11 10:21 PM
02/14/11 10:21 PM
USA
USA
So with the dome of the KB 400 are there any issues with valve clearance or?
If I don't zero deck the block and just slap on a set of Edelbrock 84cc heads, .040ish head gasket and KB 400s what would be CR be?
Re: 383 Quench Question [Re: 71383beep] #926037
02/14/11 10:23 PM
02/14/11 10:23 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Holy doorstops Batman!! There's still a use for them old 516's!?!?!?
I've asked the question on the Race forum before, got no definitive answer..................Which is better quench w/compression (516 closed chamber) or the marginally better airflow of an "no quench" open chamber head (906,902,346,452)??
Re: 383 Quench Question [Re: JoesMopar] #926038
02/14/11 10:30 PM
02/14/11 10:30 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The standard answer is you need to check for your application but generally the KB400 does still have valve clearance notches they just put a raised dome that fills some of the dead space in the combustion chamber... The dome will impede flame travel & may lead to less than ideal combustion but you need to do something on a 383 to raise the C/R & a dome offers more gains than losses...
Re: 383 Quench Question [Re: JoesMopar] #926039
02/14/11 11:53 PM
02/14/11 11:53 PM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
If you don't zero deck it the pistons will likely be around .030 in the hole and only give you 9.43 with a .040 gasket or you could use a steel shim and be around 9.87.
Zero deck and a .040 gasket would be 10.11
Re: 383 Quench Question [Re: DblOJoe] #926040
02/15/11 12:12 AM
02/15/11 12:12 AM
USA
USA
Cool, would there be any chance at that point with the pistons interferring with the XE274 cam?
Re: 383 Quench Question [Re: JoesMopar] #926041
02/15/11 12:21 AM
02/15/11 12:21 AM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
No, but you should still check to see how much clearence you have.
Re: 383 Quench Question [Re: DblOJoe] #926042
02/15/11 01:41 AM
02/15/11 01:41 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you go with the KB400's I wouldn't bother doing anymore than a clean up cut to square the decks , if you zero deck it then you also need to cut either the heads or the intake to make up for the at minimum .024 off the block deck , that is the same as cutting .024 off the heads , the intake surface needs to be cut also, and don't forget the valley end rails will also need to be cut. But once you either cut just the heads or the intake that part is now married to that 383 block , otherwise later you will need to cut something to make it fit on another block.
I'm getting 10.0 with my 383 using 906's, Diamond flat top at zero , 3cc valve reliefs and heads cut to 79.8cc.
Re: 383 Quench Question [Re: Dean_Kuzluzski] #926043
02/15/11 07:52 AM
02/15/11 07:52 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I've got this same conundrum right now, or well, had it. I've decided that i'd rather have a crappier flowing head with quench for a nicer, more efficient engine than say, a possibly more powerful engine, thats less efficient, with an open chamber head and no quench. I'm still trying to figure out how far to go with porting my 516's. They dont quite port as well as the newer heads, but thats all i know. Never done a set. Until i can get a solid answer on that, i'll just clean 'em up a bit, big-valve the exhausts and shop for something better while i'm driving around on them.
And it must be just me, as i've seen no one else comment on this, but am i the only one here that has a problem with the whole quench pad idea? I understand the idea, and the need, and the lack ov better options, but it just seems so hokey to me. I'm not a fan ov domes on pistons either generally. From what i've seen, a cheap newer brand (Probe, Diamond, Ross) forged piston isn't that much more than a KB (at least where i live), and to move a pin (compression height) on a set ov pistons doesn't add that much more to the cost. I'd pay $200 more for pistons to get the true zero deck, even if it did mean i'd be stuck with 516's for a while.
Re: 383 Quench Question [Re: Pale_Roader] #926044
02/15/11 11:10 AM
02/15/11 11:10 AM
Holly/MI
Holly/MI
"Possibly more powerful....that's less efficient" Not to bash but sounds like an oxymoron.
With the variance on combustion chamber from cylinder to cylinder (w/open chamber), bowl & template porting, exhaust valve update to 1.74, cubic inch size considered, using a flattop piston, and ultimately good quench................I'd be surprised to see an open chamber combination actually make better power. And then it would only be in the upper rpm range.
Not that anyone would ever waste the time to do an actual build/dyno comparison.
Re: 383 Quench Question [Re: Dean_Kuzluzski] #926045
02/15/11 04:44 PM
02/15/11 04:44 PM
IL
71383beep Offline
71383beep  Offline
IL
Well what happened to me was a comparison. With the 906 heads and KB 162's with just a freshened deck the car ran like crud and would barely hold a tune. I had other issues, but could tell that something was not right.
On the 2nd rebuild I knew better and I had the shop pull the motor apart and we figured out that the old combo was running 7.8:1 CR...
For the second build I gave them a set of 516s I had laying around and they put in the larger exhaust valve and ported them for better flow. they also cut the deck some and I had a true 9.2:1 CR. With a CC nostalgia .474 cam and a mighty demon 650 on a street dominator intake the motor was dyno'd and ran 396/430 hp/tq. I was happy as my target was 400 hp and the car runs great. So if you already have the 162's they can be made to work.
If I had to do it again I would go with diamond pistons and I would have hunted down a set of 915s. But my next build for the car will be a stroker 400.
Re: 383 Quench Question [Re: Pale_Roader] #926046
02/15/11 04:52 PM
02/15/11 04:52 PM
[ I'm still trying to figure out how far to go with porting my 516's.
from what I gather they can flow very well but the prob is iirc the exhausts (short side??) has to be dead on by someone who knows how to do them. Might check the Muscle Motors archives & see if you can access any of Dulcich's porting articles (also has articles on other iron heads, excellent stuff)
Page 3 of 3 1 2 3
