Re: Edelbrock Thunder Series carb adjustments
[Re: gthomas]
#925891
02/10/11 11:12 PM
02/10/11 11:12 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
how big is the cam...how much vacuum you have at idle?
you need to check the metering rods...in that went it is idling the rods are down...if they are bouncing up and down you need a light step up spring to keep the metering rod down in the jet.
also make sure your timing is set correctly too...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#925893
02/11/11 10:38 AM
02/11/11 10:38 AM
Challenger 1
Cincinnati, Ohio
X2 ![](/ubbthreads/images/graemlins/iagree.gif)
[Re: gthomas]
#925896
02/12/11 12:47 AM
02/12/11 12:47 AM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
They Dont Make A Thunder Series 750 650 AVS And 800 AVS Thunder
They Are Mechanical Secondaries With Adjustable Air Doors Like Our Original Carter AVS Carbs
Now They Make A Performer Series 750 COUGH COUGH
So Lets Start With A Carb # First ???
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#925897
02/12/11 08:15 AM
02/12/11 08:15 AM
Posts: 4,794 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Isnt there any former edelbrock employees on here that can shed some light on the 750 carb thing? I read the Carter Comp series 750 was fine but yet the Edelbrock version falls short.
Keep old mopars alive.
