Re: Wife needs help..................
[Re: GLR]
#925860
02/10/11 10:51 PM
02/10/11 10:51 PM
Posts: 1,443 Maryland
Dads426
Maryland
I have a stock cast iron 4bbl intake from a 72 Police 440 that had a Holley on it from the factory. You can have it if you want to pay shipping.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: 72 RR Rick]
#925861
02/10/11 11:43 PM
02/10/11 11:43 PM
Posts: 75,098 A Banana Republic near you.
JohnRR
So, I sneaked on here with my hubby's password. He needs help.....translation......I need help. We have a 72 RR with a air grabber hood. The motor is a 440. What kind of manifold will work with a square bore Holley or Edelbrock carb? Having trouble finding a "low" height manifold that agrees with the air grabber hood. Any ideas Thanks Janet
The car has a 440 and an AIR GRABBER hood , which means it has DUCT WORK under the hood , anything other than a stock height intake can potentially hit the duckwork and BREAK IT. the CH4B is the ONLY manifold that MAY work on this car. .... but I know it will not work on a 68/69 car without the air cleaner hitting the hood, so anything other than a stock height manifold requires a DROP BASE air cleaner assembly. The choices are an Edlebrock performer , NOT THE RPM , or the ORIGINAL MP dual plane , the current MP dual plane is a rebadged RPM .
