Interior screw KIT #924599
02/09/11 05:09 PM
02/09/11 05:09 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
Who makes the most accurate interior screw kit?
I have had kits in the past come incomplete, with stainless instead of black phosphate color, too long/short, wrong head type, etc. Where do you find a distributor who has the BEST kit?
Re: Interior screw KIT [Re: TrueTripleX] #924600
02/09/11 05:17 PM
02/09/11 05:17 PM
central ohio
mopar rookie Offline
central ohio
All I can tell you is I had the same problem with my 64 plymouth interior kit, and it came from Mr.G's.
Re: Interior screw KIT [Re: mopar rookie] #924601
02/09/11 05:19 PM
02/09/11 05:19 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
I used Mr. G's on my E-body. Couldn't tell ya if it was 100% correct thou.
Re: Interior screw KIT [Re: cudarex] #924602
02/09/11 05:41 PM
02/09/11 05:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've bought from a couple of places for the last 2 early-B projects, and same thing: some of the stuff is fine, some is approximate at best. I always end up restoring some of the old fasteners and buying a bunch from McMaster-Carr.
Re: Interior screw KIT [Re: TrueTripleX] #924603
02/09/11 06:49 PM
02/09/11 06:49 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
There's no such thing.
CHECK OUT MY NEW WEB SITE !
Re: Interior screw KIT [Re: TrueTripleX] #924604
02/10/11 01:58 PM
02/10/11 01:58 PM
Anchorage, Alaska
Iceman01 Offline
Challenged
Iceman01  Offline
Challenged
Anchorage, Alaska
Got mine from Tom at R/T Specialities. Don't know if it is "approved" by the numbers nazis, but it was all there, nicely packaged separately in little bags and well labeled.
Re: Interior screw KIT [Re: anlauto] #924605
02/10/11 02:21 PM
02/10/11 02:21 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That's been my experience....
Re: Interior screw KIT [Re: 1_WILD_RT] #924606
02/10/11 02:24 PM
02/10/11 02:24 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I've got 3 different screw kits here for a 68 B and some are grossly different for the same application. Shes a mix-n-match...
