TM6 or AirGap RPM for 451 stroker???
#92457
07/22/08 11:56 AM
07/22/08 11:56 AM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Just built 451 stroker for my 68 Cuda (4spd, 3.55's), 440 source kit, Eddy large chamber heads, Engle hyd flat tappet cam (special grind K56/K58 on 114 centerline), Approx 10:1 compresson. I've got a TM6 w/ Holley 850 on it now, but would the RPM air gap yield more torque & better performance? I'm also thinking of mililng the heads for more compression or switching to the smaller chamber eddys. Want the Cuda to be a hot street car that won't see the strip too much.
Re: TM6 or AirGap RPM for 451 stroker???
[Re: bigsbigelow]
#92461
07/22/08 12:30 PM
07/22/08 12:30 PM
Posts: 75,050 U.S.S.A.
JohnRR
U.S.S.A.
RPM AIR GAP ???? Don't all big block mopar wedge engines have an "AIR GAP" intake by DEFAULT ???? just thinking out loud
[Re: JohnRR]
#92462
07/22/08 12:57 PM
07/22/08 12:57 PM
dogdays
OOPS! RIGHT, NO AIR GAP for 400s. You'll have to block the exhaust crossover to get max benefits but still a great manifold. Air gaps and regular Perf RPMs have AFAIK the same interior configuration as far as ports and plenum. R.
[Re: Triggerfish]
#92466
07/22/08 03:17 PM
07/22/08 03:17 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
My son loves the Performer RPM on his 400 Dart. It ran a tad quicker then the Street Dominator did by about a 1/2 a tenth even though it had less mph then the SD. The 1/8 and 60 ft were much better with the RPM and it was enough to keep the 1/4 et quicker then any single plane he tried and the SD was the best single plane on his Dart. He will never go back to a single plane on his combo he says even though I have out 60 ft him with the SD on my 63. But honestly Andy is so right as the RPM is great for a mild street/strip car. Ron
[Re: dogdays]
#92468
07/22/08 05:28 PM
07/22/08 05:28 PM
Triggerfish
Blairsden, CA
I thought the RPM air gap for the 383 would fit w/o any modifications. How do I block off the exhaust crossover?
[Re: AndyF]
#92475
07/23/08 11:43 AM
07/23/08 11:43 AM
Posts: 17,875 S.E. Michigan
ZIPPY
S.E. Michigan
Yep, that is part number P5153525. There is a shot of it on page 62 of the 2007 MP catalog, but I like your picture better! Oddly, it can actually be bought for less than Summit charges for a regular RPM intake, but you need a good guy parts fella who will sell at a small percentage over dealer net. At retail it's higher priced than Edelbrock...but after a little digging, I found it to be sometimes lower priced, depending on who was selling it. Personally I would really like a B version for my C body, but there is no such thing
Rich H.
Esse Quam Videri
