I went over this exact question just a couple days ago on this site.
It depends on what style the buttons are . Do they have the tab on the bottom ? Or not ? If they have the tab , carefully bend it slightly out, then pry the button off . If the button is pressed on ,
carefully , but with great force, pry the button off. Be sure to use
the very back of the button as your point to apply force, and use the metal front housing as your leverage point. You will want to remove the lense first of course, to avoid damage . You will need about a 12" long screwdriver, nut driver etc. to use as your instrument .
Or you can send the radio in and let us take care of any issues the radio has.
Greg
